drag set up on the street
Thanks
AJ
Thanks
AJ
As far as the suspension pieces, they tend to produce more noise and need to be cleaned and lubricated more often than poly type suspension components.
Not as stable in the rain
Not as much contact patch on the front so braking is hurt alittle but I never had any problems
BMR is suited better for the street car setup then most other K-members.
Wheels can be an issue if you run really light weight wheels. Prostars or Draglights would be fine.
I did it for 2 years everyday.
It makes you all fuzzy inside
