Drag Racing Tech
lets see your abs delete
Old May 20, 2008 | 12:10 PM
Tapout911's Avatar
Heres mine, sjm abs delete modified for the burkhart manual brake kit.
Old May 21, 2008 | 08:11 PM
waterbug1999's Avatar
Here is the way I did mine.
Old May 21, 2008 | 08:19 PM
JL ws-6's Avatar
Race your car!
Here, picture's not the best, but you can sort of see it.
Old May 21, 2008 | 08:23 PM
RAGENZ28's Avatar
ABS delete, took that crap off and threw it in the trash can
Old May 21, 2008 | 09:16 PM
tektrans's Avatar
Default abs
here's mine w/ a Burkhardt delete block and a bracket I made.
Attached Thumbnails lets see your abs delete-abs.jpg   lets see your abs delete-abs1.jpg   lets see your abs delete-abs2.jpg
Old May 22, 2008 | 01:04 AM
SJM Manufacturing Inc's Avatar
Attached are both our manual master cylinder ABS delete kits and our OEM master cylinder ABS delete kits. We can offer you any type of line lock or ABS delete kit for 93-02 F-body cars. We also have our new 04 GTO line lock kits and specific 05-06 GTO line lock kits.
Give us a call if you need assistance.
OEM MASTER CYLINDER ABS DELETE KIT
STRANGE MANUAL MASTER CYLINDER ABS DELETE KIT
Old May 22, 2008 | 09:54 AM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
Old Jul 2, 2008 | 11:41 AM
Ego Killer's Avatar
When you delete the abs can you just cut that bug plug off or does it need to stay?
Old Jul 2, 2008 | 11:51 AM
You can cut it off. Make certain all fuses and power is removed when you're doing so.
You can remove all the wiring as well (though it will take you some time to do).
Old Jul 2, 2008 | 12:09 PM
ALLBOTTLE's Avatar
LS1TECH Sponsor
Originally Posted by Steve Burger
Check our site. We have full kits.
We love the Burkhart ABS block... here is a picture on Tosto's Car
Old Jul 2, 2008 | 12:27 PM
89Formulaws6's Avatar
where do you guys route the wire on the driverside threw the firewall?
Old Jul 2, 2008 | 12:50 PM
  #32
Our kits include pictorials and a firewall grommet for the kit. Our kits completely remove the ABS block and ABS modulator for maximum air flow and weight reduction. It cleans up the engine bay drastically reducing install issues for turbo or supercharger setups. All of our kits include an adjustable proportioning valve which is needed to bias your brakes.
Our kits do not have any type of braided lines. All lines are hard-lines and pre-formed with all necessary fittings. I would not suggest replacing a hard line for a braided line. Braking performance will be reduced due to line expansion in the braided components.
The reason for the proportioning valve is to adjust your brake bias. When you remove ABS, you have no bias control. Equal pressure is produced from your master cylinder two ports. The chances of your brake bias being correct is about the same as being hit by lightening. Each car is different, brakes, tires, weight distribution all effects where the bias should be set. This is why it being adjustable is important.
Old Jul 3, 2008 | 02:51 PM
  #33
DanZ28's Avatar
Alright, I'm replacing the braided line I put in there now. Didn't think it would be that big of a difference since the stock ABS stuff was braided but can see how steel line would be much better.
Old Jul 3, 2008 | 03:13 PM
  #34
kkslds's Avatar
__________________
Cunningham Motorsports Online Sales & Tech Support
(951)471-2898
Cunningham-Motorsports.com
Home of the Quickest 6sp GTO in the US 10.1 @ 138mph with a Slipping Clutch
With the burkhart hit do you have to do any modifications the stock lines and if i was to ever decide to but my abs back in i could just bolt it back up and go? I've seen some of these other kits require some work to the stock line
Old Jul 3, 2008 | 03:52 PM
  #35
I believe you can do that kkslds you'd have to speak with them.
Keep in mind, you'll have no brake bias controllability, the rear wheels can have a tendency to lock up first. This can be potentially bad especially if you’re driving around a corner, apply your brake and the rears lock first...the rear end will slide out on you when you least expect it. Since the rears typically lock first, you won’t be able to utilizing full braking power. (if you suggest you’re just doing straight line racing only)
Best scenario would be all four wheels lock at the same time. This means you will stop in the shortest distance and in the most controllable manner.
You may as well just pull the fuse if you’re not using a valve and you don’t care about the space savings and other benefits. With our kit, even after modification, it would be rather simple to re-use your stock pieces. Just re-install the ABS bracket and modulator and use a union in the kit and re-connect them to the stock lines. The two main lines leading to the ABS unit...just keep them in a safe location for later (as well as the braided lines).
Old Jul 8, 2008 | 08:31 PM
  #36
1BADAIR's Avatar
Old Jul 8, 2008 | 08:58 PM
  #37
^--- now that looks familuar larry
Old Jul 8, 2008 | 09:16 PM
  #38
MeentSS02's Avatar
Kleeborp the Moderator™
Not the best pics, but you get the idea:
Old Jul 8, 2008 | 09:27 PM
  #39
LT1Formula007's Avatar
Looks Awesome you guys.... I plan on going with the SJM kit myself!
Old Jul 9, 2008 | 03:44 AM
  #40
1BADAIR's Avatar
I bet it does
