Need help choosing a tire
27'' x 10.5'' - 15'')
For 17" rims # Mickey Thompson ET Street Radial Tire P275/40R17
26'' x 11.5'' - 17'')
Personally something 26" with a 10" tread, but they don't really make that size with 16" or 17"
And if you want a 28" tire that fits an 8" rim, M&H 275/55-16 ***! Outhooks the M/T and is a lot lighter!
Al
I also don't see anything about higher gear ratio, so a stock motor with an exhaust with stock gears would slow the car down with a 28" tire.
Personally I think the M/T drag radials are the better tire, there is a reason the ET records for drag radial classes are mostly held running the M/T drag radial, if there was a better tire and it was the M&H then everybody would be using them.
I switched from M/T's to M&H's, gained .08 in 60' first time out.
Al
