Drag Racing Tech
More bad times
Old Jun 27, 2003 | 10:26 AM
Jorday's Avatar
Default More bad times
Went back to the track wednesday night and ran 12.1 at 111 was my best. I've got some ideas on what to look at. Most suggested that it's the tune on the car causing the problems. Someone also mentioned that the 26x11.5x16 ET streets are not nearly enough tire for my combination. Maybe I need to upgrade to ET drags, but I really didn't want to mess with getting 15 inch wheels to fit on the car. Maybe some better times will come with better weather.
Later,
Jordan
Old Jun 27, 2003 | 11:54 AM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
Default Re: More bad times
We need a full list of your parts and a complete timeslip along with the altitude of your track to have any sort of feedback for you.
Old Jun 30, 2003 | 04:30 PM
Jorday's Avatar
OK, sorry it took so long to reply with the mods and time slips. I don't know what the altitude of the track. It's the track in stanton, MI.
Mods are MTI S2 heads, Lunati B1 cam
MAC headers, orp, SLP catback
airbox lid. Rev limiter and shift points raised, ASP pulley, TP 4200 converter, 26x11.5x16 ET street tires, ported TB
60 1.68
1/8 7.75
1/8 mph 89.47
1/4 12.17
1/4 mph 111.22
here is another time slip
60 1.66
1/8 7.80
1/8 mph 90.01
1/4 12.24
1/4 mph 110.67
don't the MPH seem really low?
Old Jun 30, 2003 | 04:36 PM
Nine Ball's Avatar
LS1Tech Co-Founder
Did you ever get the car on a dyno and monitor the Autotap stuff like we suggested in your Internal Engine thread? YES, something is lacking with your setup, but until you at least check out your tuning, we can't help you much more.
Tony
Old Jun 30, 2003 | 07:22 PM
98TAauto's Avatar
could just be bad weather
Old Jun 30, 2003 | 10:31 PM
NickMapleT/A's Avatar
I think that's a nice e.t. for the mph.
StreetStalkerZ's Avatar
Sounds like it's mostly all in the tuning because your 60fts. are off along with MPH. You need to Atap the car or dyno,i would do both. Your timing could be low,running to rich or to lean and might be getting some major KR. All those can lead to off performace. I'm a bolt on car with the B1 cam and the last time i was at the track it was 84 degrees,80% humidity and Baro. 29.90F and ran 11.90s@113 with mid 1.6 60fts. Car was spinning on the launch a tad but the weather was aweful so your setup should be as fast if not faster given your weight is equal to mine.
Scott
Old Jun 30, 2003 | 11:02 PM
Jorday's Avatar
Tony,
I haven't had a chance to get the car out on a dyno yet, but I did find a place where I can get it done. My friend that has autotap will be out of town until sunday. Once he gets back, I'm going to borrow it from him and get the car on the dyno. Only reason I went back to the track is because I wanted to see if the car ran poorly at a different track. The first one I went to is a crappy track and I wanted to try a nice one.
Jordan
