Drag Racing Tech
Lower front air dam removal.
Old Dec 26, 2007 | 06:36 PM
  #41
Demonicbird00's Avatar
Originally Posted by VIPRETR2
I was thinking about this a little today and remembered John Lingenfelter taking the side mirrors off his LT1 bird for top speed contest back in the day. Has anyone tried this for drag racing? Should be easy enough to take off and tape over the holes. I'm going to try the taped front end, air dam, hood seal, and mirrors in the spring to see if I can bust 130mph with a cam only LS6.
i do that as well. and my rear wing is off as well. that weighs 18lbs plus look at the pics on my webshots. you want the air to close behind the car as fast as possible and by removing the wing it willallow the air to do just that
Old Dec 26, 2007 | 08:22 PM
  #42
jsmcortina's Avatar
Originally Posted by JEB99TA
After I gained 1/10th on my ET and 2 MPH with a lesser 60' time
Sure, whatever the theories are, you achieved a 2mph gain which is good.
If I get around to it next year I'd like to do some aerodynamics work on my car as it is a brick shaped object from 1968. I had planned to do some 100mph coast down accelerometer and speed tests to see what drag I'm actually getting then add a lower air dam and other things and see the difference.
There a probably large gains to be had on my car as it was designed before aerodynamics were of interest to auto makers and was not designed for high speed use.
James
Old Dec 26, 2007 | 08:39 PM
  #43
JEB99TA's Avatar
Demonicbird00 > Sounds good ... weight reduction list says the weight savings from removing the rear spoiler from a TA is 35 lbs ... you sure about the weight being 18 lbs? It's a pretty big piece of material for sure. A little backdraft never hurt the NASCAR boys, so, sounds pretty reasonable to me for drag racing. Of course, I'm sure it becomes more important to them at 160+ mph. I'll try that next time out to the track ... just waiting for it to open back up in a couple weeks.
jsmcortina > Good luck with your future endeavors and I hope you get some good results with your testing. Keep us posted with your results. What kind of car do you have?
Old Dec 27, 2007 | 04:08 PM
  #44
jsmcortina's Avatar
1968 Ford Cortina II estate.
(They were apparently exported to the USA, but I imagine they were rare and easily forgotten)
Pic: http://www.hotrodgazette.com/hrg3=1.jpg
Vid: http://www.youtube.com/watch?v=FjdcksPrVno
James
Old Dec 27, 2007 | 04:59 PM
  #45
VIPRETR2's Avatar
I don't think I'll take it that far, just quick stuff I can do at the track before I run. I normally like to run my car the way I street race it. If I was running the Silver State Classic or something like that I might try it though. Do you have any back to back results with just the wing removal?
Larry
Old Dec 27, 2007 | 07:21 PM
  #46
JEB99TA's Avatar
Yeah, I'd be curious, as well. Any results of dragging with the wing off?
Old Jan 1, 2008 | 11:22 PM
  #47
nah ive never done back to back comparisions..... im at the point now where when i go, i dont wanna waste passes persay. but a good comparision would be to do this small stuff to a near stock or bolt on car.
yeha its def 18lbs, i weighed it as i do w/ everything that i take off the car.
-brandon
Old Jan 25, 2008 | 04:12 PM
  #48
troopercar's Avatar
Originally Posted by jsmcortina
I've seen a car crash because it was getting so much uplift that he lost control and rolled it at 170mph+
James
I bet if you could see your flimsy little air dam at 170 it is pointed straight back under the car.
P.S. Often while cruising along at 170, I wonder how my air dam is performing.
Sorry, time for beer.
Old Jan 27, 2008 | 08:36 PM
  #49
Dan's Avatar
Dan
How did the Taped front end help with ET? Get any times yet Jeb?
Old Feb 11, 2010 | 02:38 PM
  #50
Elderado's Avatar
.......... Lower the car
Old Feb 11, 2010 | 03:26 PM
  #51
5.3LJimmy's Avatar
lol.... if he still has the car. Seeing as this was over 2 years ago.
Old Feb 11, 2010 | 04:34 PM
  #52
AChotrod's Avatar
I have a really really hard time believing taking of the air dam gave you 2mph. I think something else contributed to that.
Old Feb 11, 2010 | 07:46 PM
  #53
robsquikz28's Avatar
This is a very crazy thread to read, Im with ya Mike.
