what clutch are the fast cars using?
Re: what clutch are the fast cars using?
My Cartek setup worked awesome at the track, each one lasted a full racing season and about 20K miles of use. 1.4s in a 3625 lb car, all-motor, is pretty brutal on a clutch.
I'm going to try a RAM setup in the '69 Camaro now.
Tony
Tony
i'll do the adjustment tommorow , no time today.
i was thinking about reshimming the slave .
joe, how did you know i had tranny problems before???
man , you got me scared for a moment there
well i did adjust the MC to get the engagement point lower, it feels wired now?? (nothing wrong, just different).
the thing i noticed is that the engagement point moved closer to the floor board, but as i let the clutch in ( pedal going up) and after i reach the engagment point, well after the that point the pedal goes into the dead pedal feel (just like having slack), is that ok?? or am i just paranoid?
I use a McLeod single disk and have dozens of high 1.5's under my belt...funny thing is that the flywheel and pressure plate are over 2 years old and all I did was replace the disk(not that it really need it though)
Of all the cars I have driven at the track the McLeod twin disk wins hands down for engagement being smooth and easy and holding whatever people throw at it.
well i guess my clutch is toast! it slips bad in 6th with anything above 50% throttle.
time for the new clutch.
anyone used the spec stage4 ?
is it streetable?
is it streetable?
i don't think it's broken , because when i disconnect the master cylinder rod from the pedal and push the pedal in , i get some resistance . and when i pull the pedal off the floor it pops right up.
