Flashing the converter.......
Why are you only leaving at 2,500 - 3,000 rpm?
Are you spraying the car?
My car had a 4,500 stall and it left best floored on the motor and around 3,000 on the nitrous flashing the converter.
Best way to start is just launch at different rpms and see which nets you the best 60ft.
Some cars work better flashing the converter and some cars don't.
There are other things to consider, did you do the same burnout?
Was the tire pressure the same?
Do you check the tire pressure before each run?
Did they just prep the track before that pass?
What rpm did it stall to on that pass?
Do you have a log book to record settings, conditions and changes you make?
Are you spraying the car? YES
There are other things to consider, did you do the same burnout? YES
Was the tire pressure the same? YES
Do you check the tire pressure before each run? YES
Did they just prep the track before that pass? NO
Do you have a log book to record settings, conditions and changes you make? YES
I know this is probably a retarded question, but I am new to automatics......so what excatly is "flashing the converter" and how do you do it?
Basicly whatever your motor can rev to on the TB is what size stall you have. If you can really rev to 7k on the TB, then you have a 7k stall or some problem with your stall or transbrake.
If you're able to rev to 7,000 rpm there is something WAY wrong going on.
I would do as suggested, first figure out that problem, then setup the nitrous to not activate until the TB button is released, it's very easy to do and then put a two step in the car so you can find the best launch rpm.
I'd sure like to watch it leave at 7,000 though LOL.
You need to take the car out, put it in top gear, then with it around 2,500- 3,000 rpm floor the car and see what the rpm jumps too, if it jumps and pulls from 4k you have around a 4k stall, I would guess something is wrong with the TB activating, you can put it into park and rev to 7k, but if you're on the TB and it stalls to more than 4,000 something rpm something is messed up.
