How to measure torque arm angle?
Would I use the center of the axles? Or one of the rear mounting points?
Any info on this would be great.
Thanks, Anthony
To find the intersection you'd split the center between the mounting points on the rear end to the center of the front hole on the torque arm.
If you just want to know what the angle of the torque arm is stick an angle finder on it. Regardless of where the mounting holes are located in the back or front it is still either tilted up or down or level a certain amount of degrees from 0 to +/- something.
Here is an example to look at.
http://www.baselinesuspensions.com/info/4_LINK.pdf
The torque arm is basically like a ladder bar, and the lower control arm would be the same as the 4 link setup. You just use the principles of both together.
I'll draw an example give me a sec.
To get the center line on the torque arm you measure from the middle of the top and bottom mounting point in the rear to the center of the hole on the front where the imaginary line continues.
On the lower control arm you obviously measure from the center of the lower control arm bracket hole you use to the center of the mounting hole in front and the imaginary line would continue on until it intersected with the imaginary line with the torque arm.
Check out the drawing you'll get the point. IP = Intersection point.
So basically as you lower the torque arm location in the front it lowers and shortens the IP, when you raise the torque arm in the front it raises and lengthens the IP
When you move the point of location of the lower control arm hole down on the rear end it raises and shortens the IP point while raising the lower control arm location on the bracket will lower and lengthen the IP.
Sorry if the colors are not all that great, but better than nothing.
