Drag Racing Tech
Battery box install tips?
Old Jan 15, 2008 | 07:14 PM
Mark98SS's Avatar
Default Battery box install tips?
I have a Taylor box, looking at NHRA rules it appears the box should be mounted to the frame. The sides of the T-Top wells look like the closest thing to a "frame" back there, I'm considering a setup like this, pardon the rough sketch Any input welcome
Old Jan 15, 2008 | 07:56 PM
djsanchez2's Avatar
I usually see them on one of the sides. As the frame runs up the sides.
Old Jan 15, 2008 | 09:15 PM
RAGENZ28's Avatar
You don't have to weld it to a frame, it just has to be securely mounted, if you want to mount it in the t-top hump, just use the bottom tray and mark the holes and drill them, should be 3/8".
I had mine mounted exactly the same few years back without any issues.
You could also put some large size washers on the bottom if you wanted to reinforce the area a bit.
Old Jan 16, 2008 | 04:11 PM
Mark98SS's Avatar
Anyone have pics of installs that passed tech?
