cut in 9" moser axle
aftermarket backing plate...no problem
the machine shop wants me to pick up the axles, and they said they will draw a written agreement that IF the axle breaks in the spot where the cut is, they will replace the axle...should this be taken care of now or later?
Its very common to use a cutoff wheel and then a chisel to split the bearings, its also common to go a little deeper than you should or slip and cut into the machined surface. Only thing is if the cut goes too far towards the inside the moser rears use an extra seal inside the housing to keep oil in, if the cut is where the seal rides then it has a chance if leaking. But I know guys that dont use the inner seal and have no problems so..
But its your car and your axle, if it bothers you that much send the axle to Moser and see what they say. If they give it a thumbs up then thats that, if the say you need a new axle try to get the machine to pay for it. The machine shop isnt going to do anything because people on an internet message board say something, but may if Moser does..
