Drag Racing Tech
what holes for lca relco brackets
Old Jan 20, 2008 | 04:44 PM
ls1pwrdss's Avatar
Default what holes for lca relco brackets
ok my car isnt lowered which holes should i mount the lca's into for the relocation brakets on my new 9 in
Old Jan 20, 2008 | 05:28 PM
RAGENZ28's Avatar
Hole many holes are there?
Old Jan 20, 2008 | 05:42 PM
flyinZ's Avatar
Bottom set of holes.
Old Jan 20, 2008 | 06:24 PM
Jon@BruteSpeed's Avatar
LS1TECH Sponsor
I tried lowest holes and lost .10 in the 1/8th, currently running 2nd from bottom.
__________________
95 Pontiac Formula- Stock engine with ATI Procharger, Moser 12 bolt w/4:30 gears, Rossler trans, Neil Chance 4000 stall, M/T ET streets, 10.914@ 121.90mph, 1.452 60ft. GMHTP November 2010 Feature Car. Check it out at:
https://www.motortrend.com/features/...ebird-formula/
http://www.youtube.com/watch?v=abZ1z...ature=youtu.be
Old Jan 20, 2008 | 06:36 PM
Shawn @ VA Speed's Avatar
every car is going to need a differnt set up,we generally start out with the lower control arms level with the ground,so whatever hole makes that happen
Old Jan 20, 2008 | 07:04 PM
ls1pwrdss's Avatar
cool i figured the lowest holes but wanted to make sure.
Old Jan 20, 2008 | 07:08 PM
ABA383's Avatar
I started in the second set and then switched to the lower holes, but every car is different...You just have to experiment with what works...
--Alan
Old Jan 20, 2008 | 07:11 PM
flyinZ's Avatar
I always thought the rule of thumb was...that you wanted the LCA, at an angle...
Old Jan 20, 2008 | 07:14 PM
RAGENZ28's Avatar
If it is a 3 hole set up try the lowest and middle hole and see which one works best.
Old Jan 20, 2008 | 08:27 PM
Matt D's Avatar
Retired Street Racer
I always use the lowest hole. That is what works for my car.
Old Jan 21, 2008 | 06:43 AM
Out1aw's Avatar
Most run on the lowest hole.
Old Jan 21, 2008 | 06:47 AM
JL ws-6's Avatar
Race your car!
Depends how fast the car is. If it's a 12/11 second car I'd put them in the lowest hole, but if it's a faster car, say 10.5 or faster, the lowest hole may not work as well.
