my 60fts SUCK!!!
its currently a 400rwhp h/c ls1 with a built 4L60E and a yank ss3600. battery relocation, no a/c, no rear seats, stock 3.23's and mt 17" dr's. suspension mods consist of:
k member
sfc's
lca's w/relo brackets
adj ta
qa1 12way on all 4's with 300# spring on front
any and all sugestions will be greatly appreciated
Also list more about your combo, rear spring type, where your shocks are now set, pinion angle, location of LCA in relocation brackets (which hole), angle the LCA is pointed, raised or lowered car, brand of TA and is adjustment just pinion angle or can you adjust the front mounting location to name a few.
First things that come to mind for me would be getting a set of 15" rims, skinnies up front and 15" in the rear to gain better tire selection and then the gear ratio, 3.23 isn't that great, so list the tallest tire you want to run and the max rpm you rev the car too.
To some it up, gears, chassis tuning, better tire are probably the things you'll gain the most from in that order.
ragenz28, sorry for not being more specific. i'll try and give you some better info
it runs 7.6's at 93mph in the 1/8 (dont have a 1/4 track near). stock rear springs with the retainer cups removed to lower the car a little. i usually set my shocks at 0-1 in the front at the track and 4 on the drivers side and 5 on the passenger side, but this area is where i need the most help. pinion angle is -1 to -1.5*. lca's are in the bottom hole on the relo brackets. the front end is lowered just enough to be level with the rear (see info above). bmr ta with pinion angle adj only (but have debated buying a relo crossmember from yank).
3.23 with a stock height tire is fine.
A 150 shot will get you better 60`s
my 60fts need improvement also but I only got 7 passes on the car so far and my best is 1.48 but I think I can get that down to 1.40
Also I see you run the rear shocks at different settings, so I am guessing you need an anti roll bar and yes it will help.
I'd look to run around mid 1.5's with that current mph.
What rpm do you shift at and what rpm are you at and in which gear when you cross the finish line?
but you can try adding some air pressure,the best way to leave with a car like yours usually is to spin the tires a little to get the rpms up into the engine's power range,just try adding more pressure a little at a time and see if your 60's dont get better
ragenz28, i have no adj lca's w/poly ends so maybe i'll try some more pinion (by more, do you mean closer to 0 to +1 or -2 to -2.5?).
i shift at 6800 rpms and cross the 1/8 at the very top of second. if i put it in 3rd, it'll actually shift into 3rd just a few feet before the line so i hold it in second for best results. i would absolutely be thrilled if i could get it into the 1.5's. thats more of what im expecting
If you have poly/poly LCA's I would try between -2 to -2.5 pinion angle.
7.6 with 93 mph in the 1/8th calculates to 11.98@115 according to the 1/8th - 1/4 converter here on LS1Tech.
thanks again to all of you with helpful advice. any more is always appreciated
Try air pressure first, try different psi in 1 psi changes till you get the fastest 60ft, once you get that, then try the pinion angle.
If you don't have an anti roll bar I would at least use an air bag in the right rear.
Get a log book and record all the changes you make, But only do one thing at a time or you'll get mixed up.
Then try the shock settings. Maybe try the second hole in the lower control arms, mess with everything you can adjust that is adjustable, but only do one thing at a time.
Adjusting the rear shocks on my old pile was a 1/2 tenth improvement in the 1/4, travel limiting the front suspension was between being on the back bumper and leaving hovering the front tires for 100 feet 12" off the ground, adjusting the 4 link alone netted me a .10 60ft improvement alone.
Best advice I can give is get your hands dirty and see what happens when you change or adjust things, but do one part at a time and record the results.
