How to Mount Kirkey Pro Drags
Is there something you can buy to greatly ease the process of installation? If I can spend a few bucks to save a ton of install time that might be easier.
I would want them mounted to the main hoop but don't know how/what you use to mount them to the floor.
Pictures would be worth a million words if you have any.
john
when I go kirkeys they are getting bolted to the floor and supported on the cage as the others have done...
Chad
Take two pieces of tubing and bend each one 90* on each end.
Depending on how much you need the chair to stick up cut the ends shorter or longer to get the hight you want
Then weld a tab on the end of each piece with a hole on it like this that will bolt to the existing bolt holes
Then you can either use two flat strips of metal in between like this with holes drilled through to mount the seat to
Or you can use the same exact bar setup and use two pieces of additional tubing instead of the flat strips and weld tabs to those to mount the seat, or use square tubing across the center and notch it and drill the center of that for holes to mount the seat.
I made a drawing.
