Lowering the rear
I have a set of Global West rear springs(shorter) and matching height adjusters for the rear.
I want to put it back where it was and go even further, I want the top of the rear tire just under the fender lip.
How will this affect how the car hooks? Theory says it should help the car hook.
Best 60ft so far on drag radials is a 1.51, runs low 1.50's pretty consistent.
ANy input appreciated.
David
Lowering the car will lower the intersection point, it will lower the front of the LCA hole and that's why you see the 3 hole or even more 4 or 5 hole relocation kits, as long as you relocate the LCA to the angle it needs to be at it should hook fine.
I already have the Global West rear height adjusters.
Will lower it this weekend and re-center the tire.
David
If you remember the photo madman had a while back of that custom rear end, you can see how low those guys drop the LCA holes in the back, some of those guys have 4,5,6 holes so you're talking an additional 1-3" lower than the standard LCA 3 hole relocation brackets.
