Drag Racing Tech
Man there's a lot of crap under the dash!
Old Jul 9, 2003 | 07:22 AM
Reckless's Avatar
Super Moderator
Default Man there's a lot of crap under the dash!
If you are looking to trim 50+ pounds, pull the dash and remove the heater box and blower, duct work, firewall insulation, etc. Man what a bunch of crap under there. Lot's of free room now though Think I will reposition my PCM on the firewall inside the car.
Old Jul 9, 2003 | 07:34 AM
CHRISPY's Avatar
Default Re: Man there's a lot of crap under the dash!
I am looking to do the same thing soon. Any tips on getting the dash out?
Cheers,
Chris
Old Jul 9, 2003 | 08:23 AM
SilverGhost's Avatar
Motorboater
Its not too bad, just take your time Chris. Basically everything holds the dash on comes off with a nut driver and screwdriver, and don't lose any bolts
Its helpful to undo the nuts underneath the steering column that will allow it to drop down more so you can pull the dash over..the steering wheel will have to come off too so you can do this, but I'd assume airbags are going as well.
Regular puller for the steering wheel and LS1 waterpump bolts work perfect for the puller to get the wheel off.
Some nice sheet metal from Home Depot, a drill, and a rivet gun, and silicone sealant are necessary to make a decent heater block off.
um, that should be a good start, have fun.
Old Jul 9, 2003 | 12:22 PM
Reckless's Avatar
Super Moderator
Sean covered most of it. I did not pull the steering wheel. Just removed the nuts holding it up and let it hang down. The worst for me was figuring out why the top was not coming loose.
The top part of the dash pops right off. It is just held down by interference fit clips and velcro. Pop it off first, and you will see the 5 screws I am refering to along the top.
The firewall insualtion was a bitch though. I just used a utility knife with a fresh blade and hacked it all out of there.
Old Jul 9, 2003 | 12:24 PM
Reckless's Avatar
Super Moderator
Also make sure you pull the instrument cluster before removing the dash. The plastic plug for the instruments is mounted on a slide fitting behind the cluster. You may have issues if you don't remove that first.
Old Jul 9, 2003 | 12:36 PM
1dirtyZ's Avatar
you mentioned the "top part" of the dash , is that the part directly under the windshield and has theat A/C - defroster vent?
can you elaborate on how to remove that?
thanks in advance.
Old Jul 9, 2003 | 02:13 PM
Reckless's Avatar
Super Moderator
Yes....the part with the vent for the windshield. Just pry up on it with a flat screwdriver. The clips will pop free and the velcro will also release.
Old Jul 9, 2003 | 05:21 PM
GeorgeC's Avatar
Glad to hear you're making some progress Todd!
I'll have my dash out again sometime to put a full rollcage in the car, and lose a bunch of wiring. In fact, I'm planning on rewiring almost the entire car from scratch, as I don't plan to have anything but the basics...
Old Jul 9, 2003 | 05:57 PM
AndUAndI's Avatar
BIG weight removal. Only drawback here in the south is that it is DAYUMN HOT in the (black) car driving it around town. Nearly died of heat exhaustion on Monday in a traffic jam on the freeway.
But it is a big help weight wise. Also very handy to get wiring done now as the car changes over time.
Oh the price we pay, oh the pains we endure.
Old Jul 9, 2003 | 06:16 PM
Magnus's Avatar
LS1TECH Sponsor
Excellent info guys.
I was considering doing this weight reduction but I'm not sure if I could live without heat in the winter time. I do like to drive my car year round as long as the roads are dry and not salty.
They do have in car heaters that plug into your cig lighter.. always an option.
Old Jul 9, 2003 | 06:47 PM
Reckless's Avatar
Super Moderator
My car isn't gonna be a driver really any more, so no big deal. I will just cruise it up to QS&L from time to time. Otherwise, just kicking butt at the track.
George, you can see from my new sig pic that I am also rewiring everything. I plan on mounting the PCM inside the car and eliminating much of the engine bay clutter. Will mount my small Hawker battery near where the heater box was.
Old Jul 9, 2003 | 08:16 PM
Skelton's Avatar
Hey George, wanna do mine once your done with yours? Florida road trips are fun This is definately one of my next to do list items.
Old Jul 9, 2003 | 08:35 PM
CHRISPY's Avatar
Thanks for the information guys!!
I am going to clean all that crap out of there soon
Did you replace the steering wheel with a grant wheel?
Anything special in replacing that?
I am going to remove the airbags, heater core all ducting, blower motor and leave in the radio.
I really like having the tunes blasting when driving to the track. In particular Alice in Chains Dirt and badmotorfinger by soundgarden hehe
Chris
ps- Did you remove your ABS? How is that for street driving? Greatly increased pedal pressure?
I LOVE how my car stops now with the powerslots but wouldnt mind cleaning out as much **** from the engine bay as possible. (Including ABS, powersteering pump and reservoir and maybe relocating the coils)
Old Jul 10, 2003 | 07:15 AM
Reckless's Avatar
Super Moderator
My ABS has been gone for some time now with absolutely no difference in driving at all.
Old Jul 10, 2003 | 08:46 AM
Motorboater
I replaced my steering wheel with a Grant one, yes. Wasn't hard, just make sure you put it on so that it looks right, as in don't put it on cockeyed so the car looks like it has major alignment issues or something.
Oh, I will now pass on to you a tip you will thank me for forever for the steering wheel.
You will need an adapter kit for the grant wheel to fit on your car..only they don't make one for newer f bodies...
so my friend and i figured out by a bunch of trial and error which one it is. its the newest GMC truck kit available..197X-1984 years GMC TRUCK adapter kit. It will slide right in.
I have now just saved you alot of time and a big ******* headache
Old Jul 10, 2003 | 10:04 AM
Larry's Avatar
If we have a wreck on the street with the ABS removed or another modification to the breaking system couldn't we be in bad trouble with the law. If it your fault and somebody gets hurt I believe they impound the car in most states. Anybody know what the law says about modified breaking systems?
Old Jul 10, 2003 | 12:48 PM
Reckless's Avatar
Super Moderator
Great info Sean. Which wheel did you use?
Larry...do you really think someone would go looking to see if your ABS was removed? Sounds kind of unlikely to me. But stranger laws have existed.
Old Jul 10, 2003 | 12:52 PM
Motorboater
Todd, the adapter kit info applies to any Grant wheel you happen to use. I got a basic Grant black wheel, not sure what its called, its simple and smaller in diameter than a stock wheel so its easier to turn the car without power steering.
Old Jul 10, 2003 | 02:17 PM
CHRISPY's Avatar
Thanks man that is a BIG help! Have a part number for the adapter?
Todd how is pedal pressure etc?
thanks,
Old Jul 10, 2003 | 02:27 PM
Reckless's Avatar
Super Moderator
The brakes feel no different than they did with ABS. Absolutely no difference that I can tell.
Sean...so that adapter you mentioned will work with any Grant wheel? Or are there specific applications just for the f-body?
