Please analyze my video ....
if you want to go all out, get and adjustable panhard and center/square the rear to be sure the suspension is working for you 100%.
If possible, try to get a vid from behind and to the side of the car so that you can see the tire all the way to the ground.
What anti roll bar do you have?
What size and type of tire were you running?
The motor bogged some, I would try leaving at a higher rpm, 5500-6000.
Don't change a lot of stuff at once, I'd get the adjustable shocks and work on the tire pressure and launch rpm.
Front Sway bar removed?
What are you launching at? 4500
Tires, pressure?
lca relocation brackets? Y
Rear tires are?
I would do front and rear drag shocks. If you were auto you could just do front shocks but since you are M6 you need to do rears to since you might need to stiffen them up to mitigate wheel hop. I suggest QA1 shocks I think they are the cheapest. And it did sound like you bogged a bit.
Do that before you spend a lot of money on parts.
Also get a log book and record all the settings for each run, tire pressure, which lane, what rpm you leave and shift at, shock settings, anything you can think of.
