Drag Racing Tech
Different use for MAF Translator, question...
Old Feb 3, 2008 | 08:45 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
Let's say you are 11.70 on average. You might be able to fatten it up to slow down a tenth, maybe two, hard to say. At some point you will be so fat you will foul out plugs.
And I would still add weight, easy to do. Put the jack and spare back in for example.
Old Feb 4, 2008 | 09:30 AM
5.3LJimmy's Avatar
So, what if he adjusted the throttle cable so the TB doesn't open all the way is that also cheating? The rule is for an electronic throttle stop that is programmable, not a throttle limiter as I suggested. How about a block of wood under the pedal? Would this get him DQ'ed as well?
Old Feb 4, 2008 | 09:39 AM
Matt D's Avatar
Retired Street Racer
The block of wood would get him DQed. That is unsecured/illegal ballast.
Old Feb 4, 2008 | 10:15 AM
5.3LJimmy's Avatar
I was speaking hypothetically. Just using the block of wood as another example of a throttle limiter. If the block of wood was screwed to the back side of the pedal would it still be illegal?
Old Feb 4, 2008 | 11:17 AM
rel3rd's Avatar
good point....i'd probably be trying to slow down an average of 3 tenths depending on weather.
spare & jack never leave their homes...after all i drive car to track...
Old Feb 16, 2008 | 03:47 PM
rel3rd's Avatar
well....
FWIW, I found and bought (at a good price btw) an HPtuners setup...
Thanks for the replies and suggestions to do so.
Old Feb 17, 2008 | 07:05 PM
5.3LJimmy's Avatar
That will do it. I hope that works out well for you, and good luck at the track.
Old Feb 17, 2008 | 08:20 PM
rel3rd's Avatar
Thanks.
