Different use for MAF Translator, question...
I hope to run some INDEX CLASS Racing this year but since my car runs 11.67 at last time out (with a bunch of 11.70's as well), I figured it'd be easier to slow it down to 12.0 class than it would be to try and run 11.50 index class consistently.
My plan would be to add a MAF Translator to it and slow the car down (as needed) by richening up wot a/f mixture (also, as needed). That way "tune" is not changed except on the days i need to tweak car to slow it down...
my original idea was to lower shift points, but since my tuner isn't at track with me I'd never be able to accurately dial the ET in like I could by other means.
any thoughts/suggestions/ideas, since me running laptop tune myself is not a possibility.
Personally I'm trying to build to race a 9.5 index, and I was planning on doign it via the amount of nitrous I run. I'm hoping a 100 shot will get the car to 9.50 on a good day, if the weather/track sucks then 125 or 150 will bump it up/down as I need. Fine tuning, say by decreasing the fuel or adding fuel by one jet size if say I'm at 9.54 and need to be at 9.50 would be the next steps.
the throttle stop idea sounds good...as does the tweak the tune myself idea...
my tuner's actually the person who suggested trying the translator as a quick adjustment that i probably couldn't screw anything else up with...
good luck in the coming season.
btw, sorry for any spelling/grammar errors...i only have one finger to type with since i had surgery on left arm yesterday
i don't understand why you want to jump through hoops and play games with the rules when HPTuners can take care of it and give you the ability to update all of the other tuning for your car for years and years to come.
I'm hoping I can get my Camaro down to 10.5's on motor so I can run 10.5 indexes, it would be even better if I ran 10.40-10.45.
as for the throttle stop idea, there's nothing wrong with using, or bending, rules to your advantage...if nobody did, all cars in a given class would all run the same....very boring, imo
the racers that do use the rules to their advantage are usually the ones who win...it is not cheating, since you aren't breaking a rule, but it is surely using the rules to give yourself an advantage...
btw matt d, this is not nmca class...it is local east coast n/a index class racing
since lowering shift points would surely work, i'm going to research if a predator setup to only modify "stock" tune would work for me....even though in all reality, it's no different than other ways of slowing the car down a little imho....i mean, does "cheating" via the pcm make it more ok than a screw in the throttle linkage? i really don't think so.
it still will come down to car's overall consistency, and driver's skills on the starting line
i don't see what is so impossible about changing one little part of your tune, the cost of those shitty handheld tuners is almost as much as getting set up to do actual tuning.
regardless of how good your tuning guy is, he can't be everywhere and take care of everything. learning how to help yourself does come in pretty handy sometimes, this is one of those times.
with only 1 finger to type with, i can't keep going back and forth about our opinion differences...
thanks for the replies....time for a nap
i can borrow it for free and see if it works "good enough" for what i need.
it'd only be for a half dozen races, so i want something that is easily reversed, or removed.
now if my recent suspension mods & upcoming re-tune for the ls6 intake and new single in/out catback get me a few tenths quicker, i'll be in fine shape since i could just run the 11.50 class instead of 12.0 class.
i just figured murphy's law would prevent that and it'd be easier to slow down than to quicken up.
i'm not sure how i'd be able to use a restrictor plate....any ideas?
