Quick and dirty camera mount
I made it out of 2 aluminum bars from Home Depot 2"x1/8"x36" $10.88 each. Got a few small bolts and nuts and got to work. I cut about a 6" piece off of one the bars mount to the rear dome light. I drilled two through holes for the dome light bolts and four holes to bolt to the upper leg of the mount. I attached two strips of weatherstrip in between the 6" piece and the dome light to keep it from getting scratched up. Here is a pic of the upper leg and the dome light mount attached.
And the upper leg of the mount with the camera attached.
I tried to use the camera mounted without the lower leg but it wasn't stable enough and set off the shock sensor on the camera. Then I fabbed up the lower leg. I used the camera mount through bolt to attach the upper and lower leg and slid the bottom of the mount under the center console.
I sprayed it quick with some black paint for the stealth factor. I ended up cutting about 14" total off of the top leg and about 10" off of the bottom and there was trial and error bending and re-bending but nothing major. That's it, maybe this will help some of you roll bar-less people out. Sorry, no vids yet. By the time I got done it was time to start V-day dinner for the Mrs. In fact I need to go take the steaks off the barbie right now. Thanks,
Larry
Larry
Larry
Every time the action starts the camera cuts out. I have alot of footage of right before I stomp on it, lol. Maybe if I can isolate where the camera mounts with some rubber or something it will record correctly.Trending Topics
Every time the action starts the camera cuts out. I have alot of footage of right before I stomp on it, lol. Maybe if I can isolate where the camera mounts with some rubber or something it will record correctly.the only way around this is to remote mount the camera in a padded box and run a cable to a stationary mini cam.
I am going to post links to more photos of the housing for those who want to check it out. I feel like I am sucking up alot of bandwith
I even have enough of the CD case left to make 2 more housings
http://i34.photobucket.com/albums/d1...RETR/007-2.jpg
http://i34.photobucket.com/albums/d1...RETR/002-3.jpg
http://i34.photobucket.com/albums/d1...RETR/001-3.jpg
http://i34.photobucket.com/albums/d1...RETR/006-2.jpg
http://i34.photobucket.com/albums/d1...RETR/005-1.jpg
http://i34.photobucket.com/albums/d1...RETR/004-2.jpg
Now I have to get more time to shhot video and learn how to edit them with Windows Movie Maker. Thanks again dlove. When I get may rollbar installed I think I'll get a project box from Radio Shack and make one a little nicer.
Larry
yeah i was like, i wonder if i should tell him about our experince with this. Then i was like nah we had issues on a 600hp+ porsche gt2 race car, I bet this will be fine
I just think it's a little too violent with the Pro-Shifted trans for a solid mounted camera. Thanks again for the help and the tip on WMM.Larry
$60 and they work amazingly. A local guy has one. You can stick them on the outside of the car too. They are rated to 175+mph so you know they'll stick.
