Drag Racing Tech
ET Guess?
Old Feb 24, 2008 | 06:08 PM
MetallicaMatt's Avatar
Default ET Guess?
Okay, everybody hates these, but I'm don't really care what the car will run, I just want to make sure I have the proper setup
402rwhp NA plus 150 shot off the line, clutch dumps with my 2 step
MT et streets in the back, 28x11.5 and 26x4 upfront on Bogarts
Rear suspension is all adjustable and Chromoly with a Sphon TA
full weight plus 6point cage, plus my fat ***
I need to know what it will be like when I launch the car, as this will be my first year with any kind of setup like this. I put QA1 adjustable shocks all the way around, stock springs in the back and 300lb QA1 springs in the front.
I want to set the spring height/ride height on the front of the car before I send it off to get alinged. I need to figure out how much room to leave between the top of the tire and the top of the fender well.
I know I can always adjust it later, but I read it was best to set ride height before you get an alingment.
What do you guys suggest based off my car, and how much room to leave?
I don't know if I'll lift the tires off the ground or just get pushed into my seat lol
either way, still fun
Old Feb 24, 2008 | 06:26 PM
bad2000z's Avatar
High 10's at 130mph.
Old Feb 24, 2008 | 06:36 PM
davered00ss's Avatar
Moderator
High 12's.
Old Feb 24, 2008 | 06:39 PM
Moderator
seriously high 10's?
Old Feb 24, 2008 | 06:55 PM
okay sweet. 10.99 would make my YEAR lol
what's she going to be like on the launch? tires on the ground? fully unload the front suspension? tires off the ground?
Old Feb 24, 2008 | 08:54 PM
bad2000z's Avatar
Tires will likley be off the ground lol.
Old Feb 24, 2008 | 08:56 PM
TXCAMSS's Avatar
"All Motor 9 Second club member"
If you hook, I'll go a 10.72 @ 126
Old Feb 24, 2008 | 09:18 PM
RAGENZ28's Avatar
If you have 10 sec power it'll pull the tires easy, especially with nitrous, first thing is you make your first couple passes off the nitrous, see how it feels get used to doing the burnout and stage the car, if it goes straight spray the bitch and run the car, if it seems like it is doing a big wheelie, keep it floored and let off the nitrous, when you take off it feels like a roller coaster, except it slams you in the seat a little harder.
Remember don't let off the gas let off the nitrous, you don't want to f*ck your front end up!
Old Feb 24, 2008 | 09:23 PM
keeping on the gas will set the front end down softer then?
so how much space should I leave? i don't want the front tires to slam up into the upper fender well
I'm goina start N/A
then probably 75 then 150
Old Feb 24, 2008 | 09:25 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
10.8 perfect pass and if you have sprayed the car before and know how fast the shifts come up, and high 11's if you have trouble shifting in time and screw up the runs (which is what I do with stick cars)...
Old Feb 25, 2008 | 07:20 AM
Okay cool
so, high 11's with my driving
Old Feb 25, 2008 | 08:21 AM
Matt D's Avatar
Retired Street Racer
It SHOULD run low, low 10s on the hose. It depends on how you set the car up and how you can drive. Those are the two biggest factors in how to go fast. Take it to the track and see.
Old Feb 25, 2008 | 08:49 AM
ONEBADWS6's Avatar
Full weight and a 6-speed low 10's will never happen. Back in 2001-02 @ 3800lbs and a 150 shot my best was a 11.13@ 128 with clutch hyd that were crap at best.
Old Feb 25, 2008 | 09:41 AM
Jakes Dad's Avatar
Please do something for an old guy. You said all this stuff is new to you. I don't know where you intend on making these full 1/4 passes in Ohio. Hopefully it has a long shut down? Hopefully nothing will brake. Hopefully everything you've installed works. In my eyes a 1/4 mile is measured in a bunch of different things besides the FULL PASS. Launch, first 60' etc. etc. I ask that you forget the reaction time. Go when you're ready. Get used to confirming the rpm that achieves the best 60'. Get those sounds mentally into your head. Figure out when you can SAFELY hit the 150 shot of nitrous.
I admit to being dumber than everyone on this board, old too. Everyone prior to my post thinks everything is going to come naturally for you. "I would shake a new car new driver down with a few passes before I tried that ***** to the wall pass."
Good luck I hope you do better than anyone has said you should do.
A grumpy sometimes angry old man and his dog - Jake
Old Feb 25, 2008 | 10:13 AM
I appreciate your post. I race at Norwalk Raceway Park. Best track in ohio. 1/2 mile shut down (because we get a lot of jet cars) and then open grass field after that. ALL of my runs will be done when myself and a local shop has the track rented out. Which means not only is there only a few people there, I will have honest friends to watch me and help me out, I get to take as much time as I need, plus there is also EMT's watching should something go wrong.
I don't have the ***** to just go up there and hit the juice. I'm going to start with just a few light slow runs down the track to make sure of everything. Then work on launches for awhile, then work on shifting. Then when I'm comfortable I will slowly start the juice. 75 shot up to the 150. We get the track for 6 hours so I'm not rushed at all. If I don't feel comfortable, I wait until next time.
I guess I'm different in the fact that, if I suck at drive and I only get high 11's...good enough. But if I know my car can do 1?.XX then that makes me happier.
I just want to make sure I have my front ride height set to the right adjustment before I start to pull the tires. Is there a guideline on how much room to leave?
Old Feb 25, 2008 | 11:30 AM
Matt D's Avatar
Why did you quote me? Have you taken your meds today?
Old Feb 25, 2008 | 11:47 AM
probably since your the only one to have faith in my driving ability to see LOW 10's lol
really low 10's though with my heavy car?
Old Feb 25, 2008 | 12:13 PM
LS1Tech Co-Founder
My Camaro is A3 and runs 10.dohs@133-134 on a 150 shot, and I'm 3300 raceweight. I think I have a bit more in it, but I don't see a full weight M6 at 3800 raceweight running that good. I think Bill's 11.1@127 is what I would think. I think high 10's would be on at least a 1.5 and you'd have to hit all the gears.
Old Feb 25, 2008 | 12:40 PM
Matt D's Avatar
If you get it to hook and everything works, then I could see it with 550hp @ 3800lbs. You have a 6 speed so that is going to hurt you. I like to be optimistic, but for your first few passes, low 11s will probably be what you run. You have to get it all dialed in, and that might take some time.
For reference, at 3100lbs with 340hp, I went 11.40. 4,000 rpm foot brake on a 8" slick.
Old Feb 25, 2008 | 12:44 PM
silverbeast's Avatar
Joey's car from Tick Performance is a cam only car w/ a 150 shot and it has run a 10.51 @ 129 . full weight m6.
