Drag Racing Tech
comp engineering shocks
Old Mar 4, 2008 | 05:44 PM
GregWS6&z28's Avatar
he is right. comp just switches the compression/extension numbers around
Old Mar 4, 2008 | 06:06 PM
BLOWN SS/T's Avatar
Originally Posted by RAGENZ28
You compress it then turn it a few times to make sure it is engaging the mechanism, then align it with the mark you want, then extend it, once it is extended turning it one way or the other won't effect the valving.
Alright that's what I wanted to know. Thanks
I set it to the 50/50 then extended and installed, but after installed I noticed they werent aligined.... And wasn't sure if it kept the setting that was put on before extending.
Thanks
