Drag Racing Tech
What RPM do I dump at??
Old Jul 19, 2003 | 02:15 AM
TOXIC-Z's Avatar
Default What RPM do I dump at??
Alright i posted my times earlier now I need to know how to improve them. I read about guys dumping the clutch at 5000rpm. On the Goodyear F1's I let it go at 3000rpm and got a cubic butt ton of wheelspin. Do I just rev it and slowly let out on the clutch or just pop like I did earlier. I tried easing out the last few times and did ok but the bog off the line is killing my times.
Old Jul 19, 2003 | 05:06 AM
Formula 1's Avatar
Default Re: What RPM do I dump at??
If you are going to continue to use stock radial F1's than you will have to feather it off the line. If you spend a little money and buy the ET streets you can launch at 4000+. I'm not saying this will be the best thing for your rear end, but you still have a warranty!
-Travis
Old Jul 19, 2003 | 02:43 PM
UnbelievabLS1's Avatar
Try slipping it kinda quick from 45-4700.
Old Jul 19, 2003 | 03:03 PM
Kent1's Avatar
Get some drag radials such as nitto's or equal where you can get your sixty foot down. Nitto's require a long burnout by the way. Cheers.....
