A disappointing 13.4's (Need help!)
See if someone will let you borrow their skinnys when you put the 16's on and I bet you will be supprised at the improvement
Good Luck!
Bone stock I went to Bowling Green, KY (beechbend) and ran 13.62 @ 102.51.
I dynoed at 316rwhp and 348rwtq completely stock, A4 TA.
Later I added the following mods:
SLP Air Lid w/K & N Filter
SLP 85mm MAF
Smooth Bellows
Free ram Air mod
Tranny Cooler
TCI Super Streetfighter 3500 Stall
Hooker Cat-back
3.73 gears.
And still running the factory crappy tires. However with just the performance mods in place (before installing the gear/stall combo) I dynoed 301rwhp and 317rwtq. Was like WTF! Though mods were suppose to add power. . .not loose it.
Turns out according to the shop the Barometeric pressure was the problem as in April that, the humidity and temp was much calmer than was it was a few weeks ago when I had it dynoed again.
But currently when I punch it, it hits the rev limiter on every shift. I'm going back to the shop this Saturday to get it Dyno tuned with LS1 Edit and see what happens. I'll take her to the track that night and give a few more runs and post back my times.
btw we thought the MAF was the problem and removed it, installed the stock one back and the dyno numbers only got worse so we put the 85mm MAF back on.
Good luck either way. But for the rev limiter, I could be off but you may need to get your shift points modified. What they claim they will have to do with mine.
So I guess I can live with 13.1 for right now since I have a full system, 2inch drop, and 18's. I'm gonna be picking up some lower control arms and throwing on the 16's for the next runs.
PSJ - Well looks like my MPH increased to 105 like you said you wanted to see, but I need to do better on the 60ft to get the 12.8. Oh yea you look like some actor, but I don't know his name lol.
BTW, keep in mind your running smack dab in the middle of the summer, so expect your car's trap speed to pick up some come the cooler weather of the fall.
Glad Speed Inc got your car running right,
Mike
(Always pick the best looking actor or I will have you disposed of)
Your car sounded pretty good going through the gears. If you took the spare, jack, your sub, and your amp I think you'd hit 107mph no problem.
Your car did not leave the line that hard. I think you could probably leave harder on non-drag radials...
You always got a quick jump on me out of the hole but it stayed that way the whole way down the track. God I gotta get a converter!
I need to do more mods soon!
. I have the Eibach Pro kit (1.2 in) and the best 60 ft i could get on E/t streets before the relocation brackets was a 1.84 and with them on i ran 1.73's all day long at the CZ Nationals this weekend.
Just tryin to help ya out. Oh and in the heat i ran 12.77 @ 108 with a 1.73 60ft ,now i want skinnies and cooler air. Good luck.
Dave
