A disappointing 13.4's (Need help!)
Here's performance and susension mods:
SLP Lid w/ K&N Filter
SLP Loudmouth
Vig Torque Converter (3200 stall)
B&M Supercooler (Trans cooler)
Speed Inc Basic tune
Eibach Sportline spirngs
SLP Strut Tower Brace
BMR Adj Panhard rod
BMR Relocation Brackets
***Ran with 18 Z06 rims with Michelin sport tires.
------------ Here's a few stock items ------------
Fully loaded 2000 Camaro Z28
2.73 gears
Stock themostat
Now here are my 2 best runs (only ran 4)
Reaction -- .668
60 ft ----- 2.085
1/4 ET ---- 13.484
1/4 MPH --- 104.88
Reaction -- .677
60 ft ----- 1.997
1/4 ET ---- 13.439
1/4 MPH --- 101.82
So I thought with my mods I'm supposted to be in the mid 12's, high 12's at worst? My friend tim has about the same things done except his is stock height and a few extra little bolt on's and he ran 12.6 (Which we still thought wasen't the best).
Also this whole boggin issue once I reach 100 seems weird. I mean Speed Inc said they rid the speed limiter. And I really think my MPH does seem low... when I did a crap run just for the hell of it my MPH was 108...
Oh, please tell me you did the TB Bump Stop Mod or at least checked out the TB to make sure it opens fully. Mine was roughly 75% open. I picked up 2 tenths after I did it on my '00 Z28. I just saw in your sig that your car is "fully loaded". I bet it's very heavy which will contribute to slow ET's. What was the weather like? Hot & humid weather will kill mph too. I'd talk to whoever tuned your car.
...oh, and by the way you were right. You do not want to see my Cobra any time soon. :p
To be honest I never checked the TB, but will probably be doing that when I wake up. The weather seemed pretty good for racing, cool breeze and a little bit chilly out. It was a tad humid still.
Speed Inc installed the converter and did the tuning. I might have to have a talk with them because the bogging between shifts doesn't seem good.
As far as the rest of your run, your poor 60 and 2.73s is KILLING any MPH that you should have. My heavy (3700 lbs) bolt on car (headers, orp, catback, ftra, pulleys, TP4400) only went 108.XXMPH and thats with 4.10s. Your car, the way it is set up (loaded, lowered, heavy wheels, non-hooking tires, etc) is about as far away from dragstrip friendly that it can get. If you had some tires, you could probably cut a good .4 or .5 off of your 60 ft times, which would translate to .6-.8 in the 1/4.
Honestly you don't seem to know whether you are hitting the rev limiter or getting some tq mgmt, so you might want to have an experienced person drive the car and give you some ideas. I got a mostly stock 00 to go 12.85@110mph (FTRA, cutout, lid, filter, stock wheels, 3.23's) in great spring year last year... Look me up if you maybe want me to drive it or suggest another driver who runs good with similar mods.
I'd be looking for a 12.7-12.8 right now because I'm unsure of your raceweight.
, so unless I can call off I won't be able to go. I'd like to see your MPH increase to about 105mph right now. I'd like to see a 12.8@105mph to start. Hitting the rev limiter on shifts will sound like a "tap tap tap." TQ mgmnt will make the car nose over on shifts. You will see negative timing on the shifts via a scan tool.
I also e-mailed Speed Inc since they are open and we are gonna try to see if their is anything wrong.
I still think that if you get the amp, sub, jack, and spare out of the trunk (150lbs savings) and get some drag radials, you're 60ft will drop to the 1.7s or faster for sure, which will get you to about a 13.0 in the 1/4.
Also, the issue of hitting the rev limiter or torque management (which ever ends up being the problem) is definitely holding you back some too.
So those two things, and it's mid-12s for ya.
And don't worry about the rev limiter/torque management problem, Speed Inc will make it right!
. I called speed inc in the morning today and we both had time around 2ish so I was able to take it in. Gave Larry the keys and he had one of the guys take the car with LS1edit. After about 30-40mins he finished driving the car around and said the shift points needed to be re-tuned, so he did that and that it was a little low on trans fluid (dumb me never checked at the track), so he filled that up again. As soon as I started driving the car I noticed a difference. The car seems to now shift better and harder, the car seems more reactive with the throttle and it has a more "punch me" temptation to it. Also when I gave it WOT the RPM's weren't bouncing, it shifted. But this is just HWY driving, we'll see how it really does now on the track again (Gonna try to take it to RT66 after work tomorrow).I was gonna put the 16's on, but decided I wanted to see how big of a improvement the re-tune did. I might have my friend take his car and load the 16's into their and change them at the track after a few runs. But I know next time I goto the track after tues I'll for sure run with 16's and do some weight reduction. I also read a few things about drag racing that might help me out.
. My car is slow.
