Drag Racing Tech
W2W 25.5 cage pics
Old Apr 8, 2008 | 09:29 AM
  #61
kp's Avatar
kp
Almost done, figured I'd bring this one back up with a few new pics. Got to say the guys at W2W did a great job working around what was there, after doing my own 10pt a couple years ago I have a lot of respect for guys that can do this stuff on stock bodied cars. This poor car has been through a 6pt bolt in roll bar, 10pt cage and now a 25.5. Hopefully thats it for a while..
Just have to do the carpet and put it back together, turned out really nice, now I just need a few hundred more HP to utilize it
Old Apr 8, 2008 | 09:33 AM
  #62
White.Lightning's Avatar
Looks awesome. If I were to get a 6point now, could that be re-configured/added to make a 10point? Or is it totally different?
ANdy
Old Apr 8, 2008 | 09:44 AM
  #63
RAGENZ28's Avatar
That came out nice
Old Apr 8, 2008 | 09:54 AM
  #64
kp's Avatar
kp
ANdy
You can upgrade a 6pt, wolfe sells a cage upgrade for their 6pt bars so thats probably the best route. Or you can have a local chassis shop do it to just about any decent 6pt. Going from a 10pt to the 25.5 was a little different, it probably would have been more work to add onto the wolfe 10pt that was in then just cut out and start over.
Originally Posted by RAGENZ28
That came out nice
Yea, they did a nice job on it, thanks.
Old Apr 8, 2008 | 07:55 PM
  #65
Jon@BruteSpeed's Avatar
LS1TECH Sponsor
Looks nice, did you do a before and after weight difference? How much work did they do underneath?
__________________
95 Pontiac Formula- Stock engine with ATI Procharger, Moser 12 bolt w/4:30 gears, Rossler trans, Neil Chance 4000 stall, M/T ET streets, 10.914@ 121.90mph, 1.452 60ft. GMHTP November 2010 Feature Car. Check it out at:
https://www.motortrend.com/features/...ebird-formula/
http://www.youtube.com/watch?v=abZ1z...ature=youtu.be
Old Apr 8, 2008 | 08:19 PM
  #66
Villain281H's Avatar
7 Second Club
From: Gainesville, Florida # of drag strips runs: ?!?!?
Looks good Kevin. You've got a little over one week, come on and get the thing together for pinks all out Gainesville!
Derek
Old Apr 8, 2008 | 08:39 PM
  #67
kp's Avatar
kp
There is a few bars underneath, lot of them are inside the car because I wanted to keep the exhaust. When its all together I'll weigh it, didnt change anything else really so it should be fairly accurate before and after. I would guess it added 50-60lbs over the 10pt.
Derek
Already canceled my hotel reservations, if I do finish it I'm going to run the procharger bracket race in Memphis that weekend most likely. I'm going to the all-out in Norwalk in June, one a year is enough..
Old Apr 10, 2008 | 11:40 PM
  #68
kp's Avatar
kp
Did the carpet a couple days ago (ozite), I came to realize I cant do carpeting with a **** Its race car quality I guess though, now that I did it once I can do a better job the next time, made the mistake of cutting out the console hole before I was dont and it ended up too big so I had to patch a piece in. As long as the glue holds I'll be OK. The rear paert I just used the old ACC lightweight carpet, since it was molded it fell right in. Too bad its not really black anymore after being a few years old..
But its done, have to do a couple little things underneath and its time to make some passes, kinds sucks to do all that work and go no faster. But I feel pretty safe in there now. Poor car is starting to look old inside though, after being completely disassembled several times to do a few different roll bars/cages and being raced quite a bit the last four years its starting to look its age - hard to believe these things are 10 years old already..
Old Apr 10, 2008 | 11:55 PM
  #69
Caveman's Avatar
10 & 11 Second Club
Wow that turned out great Kevin very nice.
Old Apr 11, 2008 | 09:34 AM
  #70
datsbad's Avatar
Very Nice Kp !!!!!!!
Old Apr 11, 2008 | 09:52 AM
  #71
JL ws-6's Avatar
Race your car!
Looks real good KP, the carpet is tricky, I just did mine again, 2nd time around it took WAY less time, but didn't really come out much better/worse. If I wanted to take a whole week to do it it would be perfect, but like you, I said it's a race car, and it's better looking then alot of what I've seen so I will live with it.
That cage came out great, looks perfect. I do like that steering wheel, gonna have to make a point do to that now (thanks )
I actually carpeted the entire center console area, haven't put it back in yet, and am seriously contemplating if I am gonna. I kind of like the look without it.
Also looks like you have about 20 lbs of wiring to get rid of
Old Apr 11, 2008 | 02:58 PM
  #72
kp's Avatar
kp
i have seen some pretty bad carpet jobs at the track and mine doesnt look too bad, I have seen guys just throw ozite in with no glue and it looks like a wadded up black paper towel thrown on the floor lol.
I like the console, doesnt really weigh much, good place to store a tire gauge and a few small tools, run cards and whatever. Plus its easier to push my fat *** out of the car with it in there..
I'll leave the wiring for now, its probably 20lbs total if I take the fuseboxes out of the front. I have taken quite a bit of wiring out but the dash harness is still intact. Next step will be an ARC box and minimum wiring but i'm not ready for that just yet.
I just weighed it and its at 3355 with me in it. I'm 225, so I can live with that. Picked up around 50lbs going from the 10pt to the 25.5 which isnt too bad.
Old Apr 11, 2008 | 05:48 PM
  #73
SScam68's Avatar
Looking really good KP.
I wish I still had the radio and HVAC controls so I could put them back in, albeit not functional.
I just started the !wiring mod.
This is the one that's freaking me out
tackling it tonight.
Old Apr 11, 2008 | 08:00 PM
  #74
LALT1's Avatar
Looks awesome Kevin!! I was wondering why I had seen a pass yet this year.
Old Apr 12, 2008 | 12:56 AM
  #75
kp's Avatar
kp
I use the radio faceplate power button and LED to work my data logger and I use the heater fan and mode switch to turn on the EWP and fan with the car off so they still serve a purpose. I plan on rewiring the car in the fall so I didnt want too spend too much time on the !wiring mod.
I ran it at 411 in January and February with the new engine. With the small blower and 12psi it ran some pretty easy low 5.80s. Figured I would get this done and out of the way now so I dont have to worry about it if I decide to step it up later in the year.
Old Apr 13, 2008 | 08:26 PM
  #76
kp's Avatar
kp
Last pics, 100% done and ready to go. Even took it for a little street cruise yesterday with the t-tops off, still a nice driving car
Old Apr 13, 2008 | 08:30 PM
  #77
LALT1's Avatar
man that looks awesome man, just gotta love retaining the factory interior panels also!!
