Optima battery and relocation.
you will also require a battery shutoff switch
http://www.jegs.com/p/Taylor/969832/10002/-1/10367
http://store.summitracing.com/partde...5&autoview=sku
Great price, the box will fit about any battery. I think it's big enough to fit 3 of my small batteries lol. It's the lightest enclosed box your're going to find.
Taylor now has an aluminum box that is vented and is specific for an optima battery works great.Tech man said OK
Used a Jegs cut off switch mounted on the bumper cover in the center of the licence plate area,make sure you run the alternator wire to this also.
Thanks
Ray T
Thanks
Ray T
The point of the battery box is that it takes the place of a firewall. Basically in the NHRA rulebook it says you can use a NHRA approved battery box in leau of a firewall. So one or the other is fine.
Scott
I went with the Moroso blue battery box, every tech guy in the country probably will reconize it as the approved plastic battery box, main reason I went with that.
If for some reason I have a single computer type problem, I will run a dedicated ground from the PCM right to the battery, but I don't think it will be a problem. Motor has 2 ground cables on it, plus a motor plate that's bolted right to tabs that are welded to the frame, I don't think grounding the motor is a problem anymore.
