Drag Racing Tech
4.30s in an A4?
Old Mar 21, 2008 | 08:42 AM
LS1Silverado05's Avatar
Default 4.30s in an A4?
I am in the process of going back to an A4 from an M6....I have a 9" with 4.30s now, and I am wondering what size tire I would need to run to be able to make a full 1/4 run? Rev limit set at about 6,600?.. Would I make it on 28"s?
No spray for now...mods in sig...
Old Mar 21, 2008 | 08:50 AM
NX_CaGEdApE00's Avatar
i ran 28in et drags with 9" and 4.56 gears shifting at 6700 rpms and my top speed was around 121-123 mph.... so u should be fine...
Old Mar 21, 2008 | 09:03 AM
94 guy's Avatar
NX how did you get the 28x10.5's to fit? i'm trying to put a set on right now. the rear plastic bumper is about 1/4" away from the tire. please some help and maybe some pics. thanks
Old Mar 21, 2008 | 09:15 AM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
What are your shift points, 6600? I've been shifting at 6800, 4.11 gear, and 28's. Best of 123mph on motor, car needs more gear to optimize the motor setup, or maybe I can just run more converter and make up for the gear. But optimally a 4.30 or 4.56 and more converter would get this car in the low 10's.
I'm around the limit of spraying 150 nitrous right now, I could spray 200 but not with more gear. A friend of mine said he sprayed his 346ci with a 300 shot when he went 9.4 a few years ago, and that was with 4.10's. Seems tight to me but the online gear calcs say that 142-144mph might be doable with 4.10's, 28's, and low 140's traps.
Old Mar 21, 2008 | 09:34 AM
94 guy's Avatar
pro stock could you answer the ? on fitting the 28's?
Old Mar 21, 2008 | 11:17 PM
Please, since I will be needing them too.
Old Mar 22, 2008 | 09:16 AM
LS1Tech Co-Founder
What is the question?
Old Mar 22, 2008 | 12:56 PM
camscam02's Avatar
either get a set of adjustable LCA's to move the tire a bit forward in the wheel well... or start trimming the rear bottom part of the bumper... gotta get creative
Old Mar 25, 2008 | 12:01 AM
Anymore input on 26" vs 28" for my setup? All motor for now. Any advice on what tire size to go with my 4.30s? I dont want to crank past 6500 through the traps.
Old Mar 25, 2008 | 12:26 AM
Jantzer98SS's Avatar
I ran 28's with 4.30s for a short while and it will go 125, about the same as my 4.10s and 26s did.
I will be running 29.5 with 4.30's and A3, 6300 rpm or so hoping for 123-125.
Old Mar 25, 2008 | 11:25 AM
So I assume I definately wont make the 1320 on 26"s if I dont want to rev past 6500?...
Old Mar 25, 2008 | 11:32 AM
JL ws-6's Avatar
Race your car!
You can run the 4.30 with the auto, should be fine.
A 275/60 radial will fit with zero problems as long as the tires arecentered in the wheel well and the phb has the car centered, you'll just have to hit the inner lower fender in a little. The radials don't grow, so you can get away with 28 inches of tire height.
PUt a bias ply on, and that's a differnet story
Old Mar 31, 2008 | 10:08 PM
Will I make it through the traps at or below 6500 rpms on a 275/60?
Old Mar 31, 2008 | 11:30 PM
wootang99gt's Avatar
Old Apr 2, 2008 | 01:28 PM
RAGENZ28's Avatar
How much mph will you run? It's pretty easy to figure out, 28" tire, 4.30 gear, 6,500 rpm, then you just have to compensate for converter slippage.
Old Apr 2, 2008 | 11:14 PM
Originally Posted by wootang99gt
Try driving something with power..
Old Apr 3, 2008 | 12:44 PM
bad2000z's Avatar
Hahaha!! Owned.
