Drag Racing Tech
4th Gen BBC Project
Old Sep 21, 2009 | 01:09 PM
  #241
DanZ28's Avatar
Cul, thanks!
Old Oct 23, 2009 | 11:59 PM
  #242
94z28468's Avatar
Nice ride! Quick question.........What brand of tubular K member did you go with? I like the motor mount setup, height and location for the BBC. I saw some pic on LS1LT1.com. Is there any other mods to the suspension for the BBC other than the K member. I plan on doing a BB swap on a 94 z28 and needed some info.
Old Oct 24, 2009 | 12:23 AM
  #243
94z28468's Avatar
What brand of headers are on the BBC? Are they for 97 f-body or something else?
Old Oct 28, 2009 | 01:19 PM
  #244
ebaker's Avatar
i plan on using a BMR kmember but i think Spohn also has one for the BBC conversion.
and the headers are Hooker Headers 2455 i cant remember what car they are for but im thinking it may be a old chevelle like 70ish year model. google that number and it will show you what you need.
Old Nov 28, 2009 | 10:59 AM
  #245
ulakovic22's Avatar
It's been sitting at the shop since I got tired of working on it and there has been no progress as far as I know. He's got a couple projects in front of mine, but hopefully he will be working on it soon. If not, I might trailer it back to my place and try to figure out why the BS3 won't read cranking RPM.
Old Jan 16, 2010 | 04:35 PM
  #246
jareed02's Avatar
crank trigger?
Old Jan 16, 2010 | 05:06 PM
  #247
ulakovic22's Avatar
The crank trigger works, apparently BS3 is pretty picky about the voltage. It needs over 10 for it to read. When I start cranking it's over 10 but drops under and the RPM window in the dashboard stops reading. Everything is hooked up right, just need to verify oil pressure on a mechanical gauge and get a good charge in the battery and hopefully it will start soon.
Old Jan 17, 2010 | 12:01 AM
  #248
jareed02's Avatar
good luck man keep us posted...i wanna see this car in person and watch it make a pass.
Old Jan 31, 2010 | 03:39 PM
  #249
94camaroz28lt1's Avatar
Great project, nice job, cant wait till its up and running! Don't yank the motor out! It will be way more of a sleeper in the camaro than the truck!
Old May 18, 2010 | 04:50 PM
  #250
ulakovic22's Avatar
Update for those subscribed. I got the car towed back from the shop after sitting for 9 months. Car was left outside and broken into, but nothing was taken since it appears to be a gutted stock car.
I pulled the engine out Sunday and cleaned it up as best I could. I'm going to pull the intake and heads just because of all the water stains, oxidation and leaves that were laying on the intake and in the engine bay. There are some other things I'm going to clean up and make sure al alright before I drop it in the truck.
I already have another 6 speed so both the WS6 and C10 will be 6 speeds. The WS6 is getting my old LT1 on the tubular k-member I already have since I can use the SBC/BBC mounts on the LT1. With the added clearance of the tubular k-member I'm looking into going TT.
BBC is going in the truck now and with the added room it will be N/A for a long time until I can afford to swap pistons to lower the compression. Truck will be kept in street trim and since the WS6 is already gutted it will be a drag car and sold eventually.
Old May 18, 2010 | 04:55 PM
  #251
tektrans's Avatar
It looked soooooooo good in the Fbody!
Plans change-good luck on the future builds.
Old May 18, 2010 | 05:27 PM
  #252
ulakovic22's Avatar
It did, but it doesn't look anything like the pictures anymore. Everything is covered in pollen and any areas exposed are rusted (grounds, cuts along the cowl, parts of the block) Plus there are a buch of dead leaves in the engine bay and some of the fuel lines look funny (white stuff on them).
Old Dec 10, 2010 | 07:03 PM
  #253
xx_ED_xx's Avatar
Old Dec 11, 2010 | 11:02 AM
  #254
Tzion_ben_Arthur's Avatar
I was so interested in this project.
Old Dec 11, 2010 | 03:25 PM
  #255
AChotrod's Avatar
And the truck is clean and rust free?? You shoulda left it in the TA. It was so so sweet!! **** I just read 13 pages for nothin
Old Dec 11, 2010 | 04:51 PM
  #256
tektrans's Avatar
Take it easy on the guy, Lol
I've got one going in my TA in a couple months so you guys can follow that build when I post t up.
Old Dec 11, 2010 | 05:05 PM
  #257
AChotrod's Avatar
Ive been following yours too. There has to be a light at the end of the tunnel somewhere. lol
Old Dec 11, 2010 | 07:17 PM
  #258
tektrans's Avatar
Swear to God right?
Old Dec 11, 2010 | 11:38 PM
  #259
ulakovic22's Avatar
Sorry to disappoint you. I was disappointed as well when my car sat at this guys shop for 9 months outside and was broken into. I would've definitely loved to have a one of a kind running car, but I was tired of waiting and can't tune a BS3 myself. As far as the condition of the truck, I would imagine it has rust in the rockers as most do, other than that it's clean.
Old Dec 12, 2010 | 12:09 PM
  #260
AChotrod's Avatar
I was just joking about the truck but I was ***** deep in this thread just to find out it never got finished. I knew I should have started from the end. lol. Good luck with the car and the truck.
