a/c removal?
also, can you just run a shorter belt? or do i need to do some adjusting?
https://ls1tech.com/forums/showthrea...light=c+delete
Anyway....if you just pop the hood and take a look, it's self explanitory for the most part. Once you remove the belt and compressor just follow the lines from compressor. If it is connected to that....you probably don't need it.
If you need any other help, shoot me a PM here, FastGM, or CarolinaHP.
You aren't taking this stuff off because of a certain truck are you?
bwahahahah no, i HOPE you understand half of the potential my car has.....
thanks, i've been wanting to do it for a while... i would like a/c but i have a DD and my a/c hasn't work for a while anyway. at this point i would rather sacrifice the a/c for plugs that are possible to change while at the track. especially when i finally run the second kit.
