Drag Racing Tech
Tire Help
Old Apr 24, 2008 | 11:18 PM
LS1Silverado05's Avatar
Default Tire Help
What tire would you put under the car in my sig? What size, and what kind. I will run a "track only" set, so street wear need not be a factor, though I do go to events that are "DOT only". Im also, a bit unsure of what size tire will be just right in the 1320 with a max rpm of 6,500...Advice?
**I went with a 4.30 when I was M6, and now I am back to A4....I am trying to avoid a gear change unless it is really the way to go**
Old Apr 25, 2008 | 05:33 AM
Matt D's Avatar
Retired Street Racer
275/60/15 MT Drag Radial
Old Apr 25, 2008 | 11:51 AM
I would be very happy if that size works for me. Think that will get me through the traps under 6500 on a 4.30? I know there are caculators, Im just hunting some real world experience. Thanks guys.
Old Apr 25, 2008 | 12:01 PM
RAGENZ28's Avatar
275 60 15 should do it, it's 28" tall and as long as you get the correct offset will fit without doing any bumper, fender or inner wheel well mods. 6,500 rpm would put you at 126 mph without slippage, factor in the converter slippage with the cam you have it should be very close to what you want.
