Suspension unloading ... need advice.
My setup:
Strange 12-bolt w/ 3.73 gears, Adj BMR T/A, Bilstein HD shocks, SFC's, Panhard rod, LCA's, !Front Sway bar, stock height, full weight car (w/ seats, spare, front bar, etc removed), MT DR's 275/40R17 @ 21psi cold.
LCA's were in the bottom hole. but have been moved up. I measured the pinion angle at all points per the BMR write-up and the T/A is at -2.5. I'll be racing tomorrow morning. The track should be warm enough and the air cool enough to get some good testing done, so, i'll post back up when I get back.
Here are the vid and pics to critique. The tires plant hard ... the suspension unloads a few feet out ... then the suspension reloads again and sticks good. This was with the LCA's in the bottom hole. Adjustable QA's are in the works ... for now, I'll have to settle for the HD Bilsteins. What do you think? Is this LCA angle about right?
VIDEO link to yesterday's 11.665 run ... 1.582x 60'
VIDEO of my old 11.733 run ... 1.64x 60'
Pinion angle/LCA angle pics.
The front is coming up so hard it is unloading the rear.
You make close to the same RWHP as me and I am running 11.00 at 3700 lbs, you need some shocks
David
All from moving the lower control arms up one hole. With shocks and a little more air pressure adjustment, the car's got lot more. DA must have been high as hell. It was about 80+ degrees and pretty humid @ 65 ft sea level. Time for some drag wheels and shocks now.
Watching the video, the weight transfer was steady and looks real good now. I'll post the vid up later tonight is anyone is interested. Thanks for evrybody here who have stuck with me and given good advice.
Since rear shocks are so easy to replace, I'll do them right away. I will say that the car has always left perfectly straight and appears to be squatting a little, but, evenl on both sides ... at least that's what I think I'm feeling inside the car.
Here's the vid from yesterday ... weight transfer looks a lot better than the original vid I posted last week:
