Drag Racing Tech
Moser or Mark Williams Internals for an 9 inch ?
Old May 6, 2008 | 11:18 PM
SlickVert's Avatar
Default Moser or Mark Williams Internals for an 9 inch ?
I am about done building my Rear-End Housing and starting to look for the Internal’s
I am building a NA 440 CID estimated 800+HP, M6, car for the NA Class LSX Shoot-Out.
Based on my motor CI and heads I will have to weigh a minimum of 3,425lbs by the class rules.
I am plan on using the following parts:
40 Spine Axles Gun Drilled and Star Flanged
Aluminum Case
Steel Spool
Lighten 4.86 Gears
My question is what brand part do you all recommend Moser or Mark Williams?
Do you think I can get away with an aluminum case at this weight in a stick car?
Below is some pic’s of the rear housing
Bob
Attached Thumbnails Moser or Mark Williams Internals for an 9 inch ?-firebird-010a.jpg   Moser or Mark Williams Internals for an 9 inch ?-firebird-012.jpg   Moser or Mark Williams Internals for an 9 inch ?-firebird-013.jpg   Moser or Mark Williams Internals for an 9 inch ?-firebird-016.jpg   Moser or Mark Williams Internals for an 9 inch ?-firebird-017.jpg
Old May 6, 2008 | 11:25 PM
Juiced's Avatar
If you can swing the $$$ go MW he makes some killer stuff but very very expensive.
Old May 7, 2008 | 12:11 AM
JUICED96Z's Avatar
You might call Moser about that much power with the aluminum case. I know they don't recomend it bast a particular point.
I will most likley be going with a Fab 9 and a strange ultra case or whatever its called (aluminum). Its bullet proof from what I hear and is safe to the deep 6's or so.
Old May 7, 2008 | 12:44 AM
sr71bbjr's Avatar
whats wrong wit strange??That who i would use hands down.There parts are much nicer than moser(atleast everything that i have compared) The MW stuff is second to nun but Flat out a waste of money in a NA setup or even my 106mm turbo 25.2 car. Strange is what is in my fab 9.Aluiminuim center section aswell.
Old May 7, 2008 | 01:36 AM
SlickVert's Avatar
I forgot about Strange, I do like there stuff to.
Is their Aluminum case stronger then Moser’s?
Mark William recommended their Aluminum case and Moser recommended a to go with the heavier Nodular.
What do you think?
Bob
Old May 7, 2008 | 09:31 AM
mrdragster1970's Avatar
6 & 8 Second Club
At your power all 3 are acceptable, especially with the 40 spline axles. Strong piece, good choice.
I use all MW in fast car & slow car has 1/2 strange, 1/2 moser parts @ 1050 hp.
Old May 7, 2008 | 10:13 AM
RAGENZ28's Avatar
I think the strange ultra case is the way to go, stronger than the standard aluminum case and you can run 9 or 9.5 inch gears, so you'll never need an upgrade on the case, it's built to handle big power. It is still less expensive then the mark williams case I am sure, you buy strange when you want to go racing, you buy mark williams when your pockets are full of money
Attached Thumbnails Moser or Mark Williams Internals for an 9 inch ?-strange.jpg
