Drag Racing Tech
Shock question
Old May 10, 2008 | 02:02 AM
Jammer's Avatar
Default Shock question
I finally am making it to the track after all these years... well, caring about it anyway. I ditched stock rear shocks for single adjustable KYB's cause I had them (new). What setting should I be at...soft/ middle/harder// same on each side? I have stock springs and shocks in front, stock springs in rear. A spohn pro rear sway, non adjustable lcas andan adjustable panhard and frame connectors.,, if it matters. Is there a proven shock set up or can I please make these work at least "okay".
Also, i read about lcas on lowest hole..is there a lowering bracket these day I need to be aware of?
Thanks
Old May 10, 2008 | 08:23 AM
Navy David SS's Avatar
KYB not the best drag shocks in the world. BUT I would try them before investing in some different ones. Nothing on the front - still stock? If so, get some QA1 adjustables. Try the Middle first, and than possible move to hard. You really don't want the car to squat ...
David
Old Jun 8, 2008 | 04:01 PM
djsanchez2's Avatar
TTT. for one more go.
