QA1 settings... adding weight?
Fast forward 3 years, I make over 100 more RWHP & TQ. I've added more suspension, etc.
My suspension consists of: !front sway bar, PA Racing mild steel tubular K, QA1's w/ 275# springs, BMR tubular SFC's, BMR adj. TQ arm set at -2, 21mm rear sway bar w/ poly bushings, BMR bolt in relo brackets, BMR LCA's set in lowest hole, QA1 rear shocks, BMR adj. panhard rod. The car is full interior, and full weight. Currently I have my front struts set on 4, my right rear set on 4, and my left rear set on 3. The tires I'll be using tomorrow are 255/50-16 MT DR's on 16X8 firebird wheels.
I have a SY 3500 converter w/ a 1.63STR, and 3.73 gears.
I'm thinking of adding 50-60 lbs of weight to the spare tire well. Any thoughts? Ideas?
With the control arms at that setting it should want to hit the tires pretty hard, I don't think you are in any danger of doing what I did (see sig pic) last time out, but add another 100 hp and you coudl have issues.
If the car hits the tires really good, and unloads a little ways out and spins, try moving the control arms up one hole. I tried mine with the arms in the hole you're using when I had the M6 and was cam only, and the car would hit the **** out of the tire, hook for 10 feet then spin every time. I put them back up one hole and it would spin a little off the line then go, which ended up working better (very little suspension to adjust abck then)
If it's all over the place - I'll try 3 in the front & 5 & 6 in the rears.
As for tires, I plan on going to a 275/60-15 this fall. My current tires are temporary.
I'd try kicking the lcs'a up one hole too, having them way down like works for cars with no power, but you're making enough now so that's really not needed. Plus you have adjustable shocksto make it transfer too.
Try that, and try the shock settings I posted, see what that gets you. Drfinately ditch the nitto's, those tires for the track are useless.
I'm not a fan of slicks, and I drive this car a lot on the street. I think I'm going to move the LCA's up one hole as you suggested and play around with shock settings this fall when the weather cools off. I'll have 28" tires by then too.
Swapping the tires when you get there, as much of a pita as it is, is just sometimes the best route to take.
Try a set of m/t radials, and adjust those shocks, you probably can shop a 1/2 second off your ET's
I'll most likely pull the weight out and move the LCA's to the upper hole for now and see how much it improves. Then start trying the different shock settings. I don't want to change too much at once. I already started a log of where everything is set and will make notes of changes in shock settings, tire pressure, etc.
Thanks again for the advice/suggestions. :
