How much does weater effect ET and MPH?
Thanks guys your info will be a great help
2 degrees of ambient temperature is not alot but it counts. The 22% of humidity is nothing to sneeze at and the .15 of pressure certainly isn't either. None of these factors is these small amounts are major killers of power in themselves...but add 'em all up and there's some noticable power lost.
The biggest thing about weather is temperature because it can change soooooo drastically. You might run at 95 degrees in the summer and 35 in the winter. Now THAT will totally change the performance of your car! Barometric pressure is the next biggest killer of power (still a MAJOR factor!) and then a distant third is humidity.
https://ls1tech.com/threads/showflat...31&fpart=1
First you figure out your density altitude here:
http://wahiduddin.net/calc/calc_da.htm
Then you figure out what that time would have been at sea level here:
http://www.gnttype.org/techarea/misc/altitude.html
Very usefull
Oh and by the way I forgot to say excellent consitancy there,Way to go..... The Best V8 Stories One Small Block at Time
