Drag Racing Tech
Race water pump
Old May 26, 2008 | 09:35 PM
cainsw's Avatar
Default Race water pump
Maybe a dumb question but, what else do I need to buy if I get a race water pump. Do I need to buy a thermostat housing? This is a mod I've never thought much about until the last few days. What gains are some of you with this mod?
Old May 27, 2008 | 06:00 AM
Fireball's Avatar
race water pump has no provision for t-stat.
Unless you plan on running an alternator only, running a belt is an issue to since it doesn't have an idler pulley like the Meziere street pump has.
Old May 27, 2008 | 03:41 PM
cainsw's Avatar
PS is gone so I guess it would be good for my setup. This is a track only car. What about running an alternator, how do you adjust the belt?
Old May 27, 2008 | 04:50 PM
Fireball's Avatar
bmr makes a kit to make the alt adjustable
Old Jun 12, 2008 | 11:56 AM
BMR Tech2's Avatar
LS1Tech Premium Sponsor
Hello, we do offer an LS1 drag race alternator bracket AB001 $129.95. Here i s alink to the page and a pic of the setup.
http://www.bmrfabrication.com/misc.HTM
__________________
T.C.
Sales Pro
BMR Suspension
(813) 986-9302
Like us on Facebook!
Old Jun 12, 2008 | 03:52 PM
Coach 02 A3 Z/28's Avatar
"The Drag Racing Director"
Very nice stuff.
Coach
Old Jun 14, 2008 | 12:02 PM
TJ's Avatar
TJ
i used the bottom bolt on the front of the block. drivers side to the right of the front cover for my alternator. i welded a tab to the frame and use an adjustable rod end to tension.
i run a 4 rib belt on the a/c side of the crank pulley.
7000rpm. havent slung a belt.
i do run a small std chevy cs130 alt. its a lil smaller than a ls1 unit, i THINK.
could be worth a try. couple of rod ends and a threaded spacer will save you a buck.
Old Jun 14, 2008 | 12:20 PM
Torkman15's Avatar
10 Second Moderator
Yup these are great and go nicely with a race type WP. I bought 2 when they first came out because they offered them here for $100ea and theyre small/light...
Old Sep 4, 2008 | 02:17 PM
chpmnsws6's Avatar
if you have a 25% underdrive pulley on the crank you could just run a 29 inch long belt. Thats what I did and for the few miles and few passes, it was still tight with no squeel and good voltage, using only a 4 rib belt and not even a 6 rib.
Old Sep 4, 2008 | 03:03 PM
TINKRD's Avatar
i am running a remote WP, PS pulley and alternator. I got the BMR alernator mount and i'm hoping there's enough adjustment in it to hold the belt tight enough. i am going to need to tap the front of the block though b/c its a 6.0 iron block....
