Drag Racing Tech
A3 Guys, What Shifter?
Old Nov 23, 2008 | 01:21 PM
  #41
TJ's Avatar
TJ
Originally Posted by djsanchez2
Care to share the specific mods to make it work?
you have to shave a lil bit underneath the upper console if i remember right. there is a rib, or just some extra plastic that needs dremeling out of the way.
the shifter frame itself, i cut the entire front half off at a 45 so it would clear the front portion of the console. there was also a tab cut off, which i think was a brace to screw the plastic console to it comes with. i broke my last saw blade so i just bent it over.
looking back, i might have been able to shim up the back to keep the front at a lower angle, but im not sure how that would work out. its an idea to keep from cutting up your shifter.
ive had it in the car for 5-6 years now and it works great. not till about 6 months ago you get a lil rattle out of the shifter when you are idling at the redlight. this is usually after ive been to the track and things have been tweaked. haha.
the easy part is getting a shift **** on the stick.
i cut the a stock 6 speed stick and welded on a flat bracket with 2 holes drilled.
next i marked and cut off the stick on the ratchet shifter, drilling holes in what was left to mate up to the bracket i made
its held together with 2 grade 8 1/4 bolts and locknuts. works like a champ.
it sounds all hacked up, but works and looks great.
if you have imagination, you can do it.
Old Nov 23, 2008 | 08:40 PM
  #42
Beaflag VonRathburg's Avatar
OWN3D BY MY PROF!
Originally Posted by TwoFast4Lv
Stock with stop cut for 2nd
After the burn out I put it in 1st and then just pull back for the 2nd gear shift. then for the 3rd gear shift I push down on th ebutton and pull back again
Thread from the dead so I feal the need to ask if you have any pictures of how you made this work. I'd like to save $200 on buying a shifter if I could.
Old Nov 23, 2008 | 09:48 PM
  #43
TJ's Avatar
TJ
jegs used to sell those lockouts at one time for the 3rd gen cars, im sure the 4th gen selector is almost identical.
they werent that much either, 20-30 bucks.
Old Nov 24, 2008 | 10:36 AM
  #44
TwoFast4Lv's Avatar
I just took the shifter out and used adie grinder and a file to move the notch back on OD to D. When I pull into the box I pull it down and it goes to 2nd. I do the burn out and then push it forward to 1st. then when I launch the car when it comes time for 2nd I just pull back quick and by the time you get to third it is easy to remember to push the button and pull back again
I will try to shoot some pics later. car is in storage right now.
Old Nov 24, 2008 | 01:41 PM
  #45
OWN3D BY MY PROF!
^ I understand what you are saying. The white pieces has all of those ridges on it. You're just grinding down the OD --> D aka 1-->2 notch.
Old Nov 26, 2008 | 12:32 PM
  #46
Sandmann120's Avatar
Pistol grip Quarter Stick w/o console. Ill snap pics this weekend.
Old Nov 26, 2008 | 01:46 PM
  #47
Camaro396's Avatar
I went with the B&M Carbon Composite-x!
Old Nov 30, 2008 | 06:01 PM
  #48
koolrayz's Avatar
subscribing
Old Nov 30, 2008 | 09:58 PM
  #49
stripes1987's Avatar
i think the precision performance products shifter is by far the nicest piece but than again it is a little more expensive than alot of the other shifters
Old Nov 30, 2008 | 10:11 PM
  #50
Packy's Avatar
I went with the Hurst Quarter stick. Here is a pic:
Old Dec 2, 2008 | 04:38 PM
  #51
OWN3D BY MY PROF!
Agreed, I've been looking at a bunch of different ones recently. I found it on the coan site and noticed some people had it in this thread.
Originally Posted by Coach 02 A3 Z/28
Here is the shifter I run.
http://www.precisionperformance.com/home.htm
Coach
Coach,
Which one are you running? I don't really see that large of a difference between the three other than price. I noticed the first one has the capacity for an air shifter.
Originally Posted by ChevyGoldfinger
x2 See attached pic.
Has integrated transbrake button.
Managed to cut and fit mine into the stock A4 console.
(only lost a tiny bit of the cup holder)
Which one are you running? I think it's the kwik shift II judging by the name of your picture? How exactly does it work. I was reading the instructions and it kind of confused me with pulling the lever and pushing the button.
Old Jan 20, 2009 | 12:44 PM
  #52
stmz28's Avatar
dose any one have a pic of a Cheetah shifter in a 6 speed consold
thanks
Old Jan 20, 2009 | 12:51 PM
  #53
joelster's Avatar
I rock a th350 full-mvb with a forward pattern. I run the stock shifter. Had to drill a different mounting pattern where the cable for the shifter meets the tranny pad.
Old Jan 20, 2009 | 01:12 PM
  #54
Camaro396's Avatar
thanks
Save yourself the trouble and get an A4 console. Much easier. It was tried with the six speed console and didn't work out very well.
Old Sep 17, 2009 | 12:34 PM
  #55
nemss1's Avatar
bringing this back from the dead. how hard is it to install a B&M Pro Ratchet in an auto camaro with 4L60E?
Old Sep 17, 2009 | 02:26 PM
  #56
chrismcdaniel's Avatar
me too
http://www.summitracing.com/parts/BM...3/?image=large
Old Sep 17, 2009 | 07:33 PM
  #57
Z28/2002's Avatar
From: Your girl's back door giving her the long stroke while you're at work
Here is my Pro Ratchet in a M6 console
Attached Thumbnails A3 Guys, What Shifter?-l_ef7962964bf846a583318c6905d69daf.jpg
Old Sep 18, 2009 | 12:52 AM
  #58
SIC LSX's Avatar
Originally Posted by TJ
B&M quicksilver mated with a stock 6spd stick and ****.
its all modified. it does not just bolt up....
best set up you can get
Old Sep 21, 2009 | 06:53 PM
  #59
Villain281H's Avatar
7 Second Club
From: Gainesville, Florida # of drag strips runs: ?!?!?
B & M Pro Ratchet in my Nova. Best 3 speed shifter IMHO, you can't miss a gear!
A buddy has one in his '95 Formula console, I'll try to snag a picture and post up.
Derek
Old Sep 24, 2009 | 02:07 PM
  #60
why? ?
