ATI damper, can you just run it without the A/C pulley?
I have the 10% ati damper with a/c. I no longer have a/c and just want to make sure it's ok to run this one with the a/c pulley removed. They have a seperate part number for the one with no a/c so that's why I'm a little worried. TIA for any info.
Thanks, I just got off the phone with the ati tech line and he said the same thing. Now what I don't get is, why is the damper with no a/c more expensive than the one with the a/c pulley? It makes no sence, your better off buying it made for a/c and just taking off the extra a/c pulley
it rides on the a/c side of the pulley.
its a perfect match.
cheap too. i had a bolt the right length and some heims in the shop. just tacked her up.
trying to stay simple.
LMK if you have any questions. i have a homeade backbrace on it as well. i use a factory hole in the block on that brace as well. its the only threaded boss on the drivers side front of the motor.
turn it 7000 rpm, made hundreds of passes, never slung. it will squeal when its freezing out for a couple of seconds, or if you just washed the motor(wet)
Race your car!
I have a motor plate on my car, so the motor mount isn't a concern. I could easily put that ti-rod up to the plate as well probably.
Cool, looks like I have a way to mount a 16 volt alt. now, and will be able to sell off my BMR adjustable ALT bracket and the stock ALT when get to the swap
