Drag Racing Tech
28" tire question
Old May 29, 2008 | 09:15 PM
HAMRHEAD's Avatar
Default 28" tire question
Gonna be heading to the track soon and threw on some 28" DR's on the back and didn't realize what a huge difference they are. I usually have 26". Is it okay to use a 28" in the rear and 26" upfront or is this something that isn't suggested? Might seem a dumb question but thought I would rather ask and sound dumb than prove it by running an improper set up that isn't safe. IMO I think it is fine but let me know. Thanks!
Old May 29, 2008 | 09:16 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
We've been running 26's up front and 28's in back since 1999.
Old May 29, 2008 | 10:11 PM
LS1 SPEED's Avatar
no problem
make sure you have a good amount of clearance for tire growth
let us know how the track goes
Old May 30, 2008 | 09:16 AM
HAMRHEAD's Avatar
Thanks guys!
Old May 30, 2008 | 09:20 AM
Scoggin Dickey's Avatar
LS1TECH & Trucks Sponsor
When the ABS and brake lights come on, don't be alarmed
__________________
800-456-0211 / PM / Facebook
WHIPPLE Superchargers, Procharger, Magnuson, Powerbond Sale, HPTuners packages!, Trickflow, AFR, PRC, CHE Trunion upgrade, $100 7.400" pushrod set, Custom Cam of your choice
Old May 30, 2008 | 09:57 AM
LS1Tech Co-Founder
I've gone by my 'thumb' rule. If I can get my thumb in between the cold tire and the body I have enough room for tire growth. You have a TA right? Post up what tire/wheel combo you are going to do, and we can tell you where you need to clearance. Bogarts are different from Pro Stars.
Old May 30, 2008 | 11:00 AM
FANTAZ28's Avatar
Moderator
He is running a Drag radial.... NO tire growth
Old May 30, 2008 | 09:41 PM
HAMRHEAD's Avatar
They are 15 x 10 bogarts with M/T 325/50/15's. I didn't think tire growth was a concern with the radials? I will post some pics of the clearance later.
Old May 30, 2008 | 10:44 PM
7420NW7TH's Avatar
The abs light is the only thing I can think of, otherwise you should be fine
Old May 31, 2008 | 12:51 AM
FANTAZ28's Avatar
Moderator
there isn't ... don't worry. NO tire growth!
Old May 31, 2008 | 01:42 AM
TwoFast4Lv's Avatar
You never know. His rear end might not be centered ALWAYS a good Idea to check. Some thing could be off.
I had mine out on the 325s tonite no issues. Then again MADMAN helped get it started that way
Old May 31, 2008 | 07:24 AM
LS1 SPEED's Avatar
good catch my fellow small friend !
Old May 31, 2008 | 09:18 PM
LS1Tech Co-Founder
I have 325's on Bogarts on my Form and it has occasionally rubbed, I think the body is coming down a lot more than I expected, I think I have the rear qa1's at 7/7.
Old Jun 1, 2008 | 12:05 AM
TwoFast4Lv's Avatar
I was shooting for this but had to raise it
