Drag Racing Tech
60´ question
Old Jun 22, 2008 | 10:45 PM
Reedy's Avatar
Default 60´ question
I can't remember where I heard this, or if it's even true, but someone told me that every .1 you shave off your 60´ will save you .2 on your ET. Is this true?
Old Jun 23, 2008 | 03:14 AM
Joinedthedarkside's Avatar
thats what i have been told too but in my experience the last time at the track it was not
2.2 12.9 112
2.1 12.8 112
2.0 12.7 112
1.9 12.5 113
1.9 12.4 114
so it almost seemed that every .1 i shaved off my 60ft thats exactly what i shaved off the 1/4 and every mph i gained shaved another .1
Old Jun 23, 2008 | 09:33 AM
1QuickT-A's Avatar
It all depends on the car and your setup.. No two cars or setups are exactly the same no matter what anyone tells you. That could be true with an N/A engine, but with power adders its a totally different story.. And it depends on how fast you are running as to what kind of gains you will see. Just like weight...
Old Jun 23, 2008 | 10:02 AM
Ed Wright's Avatar
9-Second Club
2.2 12.9 112
2.1 12.8 112
2.0 12.7 112
1.9 12.5 113
1.9 12.4 114
That is exactly what I, and every other experienced class or et racer I know will tell you. I believe guys that think they are gaining 1.5 or 2 X the 60' gains have more going on than they realize. I don't know how anybody can rationalize how a change in 60' changes anything else, unless the car is doing something else wrong. Something like tuning changes which effect it all the way down the track, but not just tire, shock or wheelie bar settings.
Old Jun 24, 2008 | 09:18 AM
rpmauto's Avatar
it seemed pretty close on my car.
Old Jun 24, 2008 | 11:01 AM
RAGENZ28's Avatar
Last time at the track we went 1.40 60ft 9.81, second pass with a tire adjustment we went 1.34 60ft 9.64 ET. Not debating the subject, simply stating same track, same day, same lane , pass made within 2 hours of the 1st pass we gained over the 1:1 60ft to ET ratio.
http://youtube.com/watch?v=kg4iujurWK8
Pass was N/A with a SBC, ladder bar car with a glide.
Old Jun 24, 2008 | 11:14 AM
Ed Wright's Avatar
9-Second Club
If a car is not VERY consistent they will vary that much if you don't do a thing to the car. If the lines in the staging lanes are long your coolant and air temps are usually different enough to cause that much variation. Two hours is a lot of time between passes to make comparisons anyway. The da can often change that much in two hours. When we test it is always the same lane, just a few minutes between passes.
Old Jun 24, 2008 | 01:23 PM
mrdragster1970's Avatar
6 & 8 Second Club
As said above, every combo is different. The old saying, .1 = .2 has been around for a long time.
If you do find .1 on your 60' you can expect .15 off your 1/4. Any more, then you're lucky.
Any less, there's probably another issue that needs to be figured out.
Just like weight, 100lbs = .10. Nothing is cut in stone.
Old Jun 24, 2008 | 02:01 PM
Ed Wright's Avatar
9-Second Club
Only on the internet do you find people claiming more gain than the 60' change. When I quit first time, in 1979, we had no reaction times, 60', or any other incremental times. Just 1/4 mile et & MPH. First time I heard this theory I asked one of my friends, NHRA Pro Stock racer Mike Edwards about that. He laughed, and asked are you serious? How could it make more difference down track, unless it is spinning past 60'? We were in his trailer at the track, at a race. Two other Pro Stock crew chiefs were there also. They too got a kick out of it. I have found Mike to be correct. Go to a real race, and ask an exprienced racer about it. Local test & tune nights, you could see or hear anything. Ditto local "shootout" racers. Those guys can't make two passes in a row alike anyway.
The 100lbs = 1/10th applies only to lower hp cars. The more power you make, the less 100lbs means.
Old Jun 24, 2008 | 03:04 PM
gator's 99TA's Avatar
so then is the 60' time over emphasized?
Old Jun 24, 2008 | 03:45 PM
Ed Wright's Avatar
9-Second Club
Absolutely not.
Old Jun 24, 2008 | 03:50 PM
JL ws-6's Avatar
Race your car!
I have noticed that whatever I gain or lose in the 60 foot usually is what the end of the run sees. realisticially, I can go to the track, make test hits and run the car to the 1/8th and shut it off,because whatever has happened by the time I get to the 1/2 track point is all I am going to see.
I have yet to make a single chassis adjustment that effected the back 1/2 of the track's performance.
Old Jun 24, 2008 | 03:54 PM
Ryan K's Avatar
Pathological Modifier
In my personnal experience, I've seen the .1= .15 in the quarter. Its just what I've seen.
Ryan K.
Old Jun 24, 2008 | 03:59 PM
Ed Wright's Avatar
9-Second Club
I have not talked to one single experienced racer yet that will tell you different. Most guys cars will vary some if they just let them sit between passes. That is usually either coolant and/or inlet air temps not being controlled, or the car and/or driver not doing the same exact thing everytime.
Old Jun 24, 2008 | 04:06 PM
RAGENZ28's Avatar
I wouldn't care if rick jones, jerry bickle or Jesus said it isn't possible to get more than 1:1 improvement from 60ft to 1/4 ET.
Our first pass last time out was 1.40 60ft, 9.81@139, second pass was 1.34 60ft 9.64@139, same mph, better 60ft, better than 1:1 improvement and I've seen it many times, on many cars, including my own.
It's really pointless to debate what he said she said stuff, when it's obviously been proven by people doing it countless times. If it only happens on the internet then I guess the time slips I read were make believe or incorrect.
Enough bench racing....moving on to the real world
Old Jun 24, 2008 | 04:34 PM
B18B1LS1's Avatar
I have to agree with RAGENZ28. It does of course depend on the combo and where its peak is, but for a typical rule of thumb for a typical car I think the .1 gives .15 rule is pretty good. What does it take to be an "experienced racer"? I have close to 3,000 passes, maybe I can be your first to disagree?
Old Jun 24, 2008 | 04:51 PM
RAGENZ28's Avatar
3,000 passes damn got me beat by a lot lol.
Old Jun 24, 2008 | 05:02 PM
Ed Wright's Avatar
9-Second Club
As I said:
"That is usually either coolant and/or inlet air temps not being controlled, or the car and/or driver not doing the same exact thing every time."
If you or your car can't repeat, many things can effect your times down track. Guess I should have stated that differently. I do know a lot of guys with a lot of passes under their belts, that still can't make two passes in a row the same. That is not the group of racers I was talking about.
What kind of racing do you do? What sanctioning body, and what class/eliminator?
Old Jun 24, 2008 | 05:32 PM
B18B1LS1's Avatar
If I 2-step my car at 3000 rpm with the no tirespin and cut a 1.40, use an airshifter for dead on rpm shifts, same IAT and coolant temp, same DA, and I run 10.50, what will I run with everything the exact same EXCEPT leaving at 4000 rpms this time and cutting a 1.30? A 10.40?
No sanctioning body, no class, just a lot of passes for fun. Oh well, I tried!
FWIW, I'm not argueing, just trying to understand!
Old Jun 24, 2008 | 06:03 PM
JL ws-6's Avatar
Race your car!
I agree. I've been rnning my junk for a couple years, and havea lot of good data, the engineer in me really tries to make an educated adjustment, and evaluation of every change and every run to see what's getting me what, and I have seen one thing that is consistant as the day is long... whatever I get out of my car in the first 330 equates to X amount between there and the 660, and the back 1/2 of the track is very consistant.
Last yeat @ mir for pinks, I went 10.986 @ 123.4 one run, next day, other lane, car went 10.983@123.6 Only thing I did different, was shifted the car about 200 rpm higher the 2nd run. And even that, really didn't make a huge difference.
Both runs off the footbrake too fwiw.
I've done similar this year, 9.85 @ 137.2, 9.890 @ 136.8, only change here, was the car had very little time to cool off bewteen the 2 runs, and the DA went up 12 points from the 2 runs.
I know my car pretty well, what it does off the trialer is about all it's gonna do, it's a real fight to try to get any more out of it.
It likes adjustments that are made at home, it doesn't like to get messed with at the track. Moody bitch
