Some track advice for a noob : )
I am wondering how best to launch the car? I am new to stalled autos. Its an 1/8th mile track and I will be running some 245 Nittos(I know there not great) on a 16in. stock TA wheel in the back. I also have some 295 BFG G-sports on my 17 stock ZR1 rear wheels. Which tire would be better, and what RPM should I launch at? Thanks in advance.
After you stage try two footing it, and just stab the gas. If you spin stay in it and there is your first pass. If you spin, you might not be able to come out real hard. If you don't spin, hopefully you cut a 1.8 or better. Now come around after cooling off the car with the hood up. Try footbraking 400 rpms higher than where you launched the first time. See what that does. Then try another 200-400 rpms until you find out what the converter likes. My old experience is that Yanks like being stalled up. Keeping stalling it up higher assuming you get good results. You'll know you stalled it up too high when the car just starts moving.
Keep track of what's going on. Don't drop the tire pressure to more than 22 psi cold, dropping them a lot won't help that much. They'll be 24-25psi after your burnout.
Good luck, and keep us posted.
