about to goto the track for the first time with this setup
my car is a 408 l92 setup , my t56 is stock besides the ram hd clutch, i just installed a umi body mounted torque arm and strange 9in setup that has 3.90 gears, aluminum driveshaft. i also have a set of mt slicks on light weight drag wheels and skinnys for the front. i got a set of QA1's coil overs with 1 adjustable **** on them
is a rear sway bar very important for a good launch? the guy i got the rear from did have one and was pullin some 1.6 60fts with his
what should the QA1's be adjusted to on the track?
what should my pinoin angle be at?
tire pressure?
what should a i launch at rpm wise?
any guess on my et?
exhuast will i run faster with open headers or full exhaust?
u have a linelock, generally how long should i do a burnout for?
i had true duals but the body mounted torque arm got in the way so i might be going to a temp 3in Y for the track
i had true duals on it but my new torque arm wont clear it so i have to go back to a 3in y for now, i think ill be running open y at the track
