Drag Racing Tech
Wheel Studs
Old Jun 30, 2008 | 03:36 PM
02BEAST's Avatar
Question Wheel Studs
Putting 15x3.5, 15x10 prostars wondering if ARP 2.5" studs will be long enough. Thanks
Old Jun 30, 2008 | 04:23 PM
01_ram-air's Avatar
Honestly, I would go with the 3.5" studs. Here's a little write up that I did a little while back. Has a picture of the 3.5" studs vs the stockers. https://ls1tech.com/forums/showthrea...837&highlight=
You don't want to mess with busting off studs. Here's a good friend of mine ripping off the studs that come with an aftermarket 12 bolt...
http://youtube.com/watch?v=Uwms7Oiull4
Old Jun 30, 2008 | 04:26 PM
Jordan S.'s Avatar
I had a set of the studs that came on my moser axles sheer off while I was going down the highway. I got it off to the side before the wheel shot off.
I have 3" ARP's. I would go with a 3.5"s next time around.
Old Jun 30, 2008 | 11:32 PM
CamaroRacing12's Avatar
i have 2.5" arp's on my fronts and i think im going to get 2.5" for the rear
with the spacer in the front the studs stick out past the rim like 5mm (guess) legally its suppose to be 12mm, i might get 3" for the front and put the 2.5" in the rear. i havent decieded yet........ btw i have the same wheel setup as u
i can show u sometime if ur up at ned or if im ever down at noyzee's or something
Old Jul 1, 2008 | 06:52 AM
02BEAST's Avatar
Doesn't the LT1's differ from LS1's.
Old Jul 1, 2008 | 09:51 PM
stud length? i didnt think so, maybe but im pretty sure they are the same. just the brakes are different. i will show u in person sometime if i ever see u at the track or if i ever get back down to noyzee's
