Little help on shift points for my setup
Thanks in advance!
You might see if you can contact John D. Brown, he used to frequent this place. He went something like 11.55 with his '01 or '02 TA that had never had the valve covers off. You need to pick his brain if you can find him. I have had several customers in the elevens with stock, never opened engines, but John is the fastest one I can remember.
Thanks in advance!
A good rule of thumb is that you want to shift around 500rpms higher than peak power so that the next gear you will be in the beginning of the power band. Now in the lower gears like 1st and 2nd the tranny ratios differences are greater than say between 3rd and 4th. So for example, if your car peaks at 6k you may want to shift the 1-2 at 6600, 2-3 at 6400, then the 3-4 at 6100ish. The rear gear ratio will also have a bearing on which gear you will end up in at the traps. And that's were the max rpm comes in. I see that you have a stall in the car so try and play with the shift points in your auto and look at your 1/8 mph speed and final 1/4 mph speed then fine tune it from there. Hope this helps. -Mark
I did several passes and every time it stayed very consistent: 6100ish shift point drops to 4500ish rpm. Now I don't have a dyno graph from my car but from most that i have looked up with similar mods the hp peaks around 5500 and starts dropping off good by 5600. The torque seems to stay very consistent for a wide range of rpm so its easier to land the shift in the good zone. Even if I lower my shift points to 5600 it looks like it should still land at a spot that is producing the same tq numbers as it is now.
If it were me I'd do some Z06 valve springs and shift it at 6250.
