Drag Racing Tech
stall and rear question?????
Old Jul 20, 2008 | 02:48 AM
shaun's Avatar
Red face stall and rear question?????
hey guys im going to be geting a stall and a cooler soon and had a question about my rear end. i dident know if i should of posted this in the gears and axles section so if i put it in the wrong spot mods please move.
i want to go with a 3200-3400 stall ans im going to get a cooler to go with it
im unshure about the brand im going with so ill take some sugestions on that.
how much of a stall will break a 10 bolt? my trans is stock with about 90% of tm removed and i think my line pr is bumped up a little.
i run nitto drags in the rear and i have a edelbrock adj ta,lca's with brackets, hypercoil springs/bilstien shocks. the car hooks good at the track and i dont really get any axle hop and my best 60ft so far is 1.9 flat.
Old Jul 20, 2008 | 03:08 AM
DADDY&GIRL93TA's Avatar
If your foot brakeing the car the rear should be good for awhile so you could go with a high stall matched to your car weight and motor/cam specs. 3200 to 3400 isnt really a high stall 4000 up is a high stall .
Old Jul 20, 2008 | 04:45 AM
Z-RATED94's Avatar
What he said ^. Get at least a Yank SS3600 a set of 3.73 gears, and then you'll probably need a better set of DRs than the Nittos. I know I did.
Old Jul 20, 2008 | 05:30 AM
ZV8's Avatar
ZV8
I have been pulling high 1.6 60's on my stock rear with a girdle cover, thats it. I have 255/50/16 Mickey Thompson ET streets. I also have 315/35/17 Nitto 555R DR's I use on the street but only get low 1.7's with those. Best so far is 12.34@108.7mph
