28x10.5x15S et drag
Race your car!
I trimmed the rear bumper cover where it wraps around inside by the bottom, cut off so the outside profile wasn't changed, just the inside lip is gone.
Bottom of the front there's a little tri-angle, I cut that out too, and the lower inner front fenderwell will need a littl beating. Took about an hour per side to get them to clear.
Camaro's are easier because the metal in the front isn't as close to the tire, and is only a single thickness for a good portion, transam is different.
