Drag Racing Tech
Weighed my car!
Old Jul 30, 2008 | 05:10 PM
BAKED's Avatar
The 2000 Z/28 I built was < 3100 without driver, that was with a 6 pt moly bar, 9", stock k, stock front suspension and stock brakes all the way around.
Your scales must have been off too, that's impossible with the stock K member.
Old Jul 30, 2008 | 05:23 PM
MADMAN's Avatar
LS1Tech Sponsor
Originally Posted by BAKED
Not to be a dick but I knew that, it weighs 3239 with me in it LOL
I was curious what the car it's self weighed.
Well that is the true weight. NOT without driver. When I scale a car I could care less what it weighs without driver. What were the corner weights with driver?
__________________
www.madmanandcoracing.com
225-343-9029
Old Jul 30, 2008 | 06:52 PM
BAKED's Avatar
Left front-873
Left rear-812
Right front-865
Right rear-689
Front total-1737 53.6%
Rear total-1502 46.3%
Old Jul 30, 2008 | 06:57 PM
358chevycamaro's Avatar
Shouldn't your rear suspension be adjusted to where the back tires weigh in equally?
Old Jul 31, 2008 | 06:08 AM
MADMAN's Avatar
LS1Tech Sponsor
Now we are getting somewhere. Before you go race the car next put the car back on the scales and get your preload right. You want 10-12 lbs more on the passenger rear vs. the driver rear.
__________________
225-343-9029
Old Jul 31, 2008 | 08:21 AM
ty_ty13's Avatar
7 Second Club
people dont realize how much ballast can add up to make these cars act right...
Old Jul 31, 2008 | 03:51 PM
382ssz28's Avatar
It's better to be a dick than a puss! My 2 cents.
Old Jul 31, 2008 | 03:59 PM
BAKED's Avatar
The car launches straight and hooks good the way it is. The only time I've had any trouble was when I tried to spray 300 off the line on a shitty track. I just blamed it on the track and the fact that I don't have any after market suspension on the front. I'd LOVE to be able to hit it with that big of a shot off the line and it hook. This winter I plan on getting QA1's for the front along with a tubular K member and A arms. Once I get that all installed I was gonna give you a call and make an appointment to get it all dialed in.
Right now I have a BMR extreme duty torque arm, air bag in right rear, big sway bar (not sure what brand), BMR SFC's non adj. BMR LCA's and Competition Eng. 3 way adjustable shocks. All this stuff was on the car when I bought it, I also plan on getting some adjustable LCA's before calling you. Is there anything else you would recommend me getting over this winter? I think I mentioned before that I am gonna be adding to the cage to make it a full 10 pt.
If I make the passenger side 10-12 lbs heavier than the drivers side I'll have to add around 130 LBS, what exactly will that do for the car?
Thanks for any suggestions, I am no suspension guru and can use all the help I can get.
Old Jul 31, 2008 | 04:13 PM
MADMAN's Avatar
LS1Tech Sponsor
You dont add weight you move it. Get the QA1s so we can move the weight with them. Did you have air in the bag when you scaled it??
__________________
225-343-9029
Old Jul 31, 2008 | 05:13 PM
BAKED's Avatar
I'll probably give you a call tomorrow if that's cool.
Old Aug 9, 2008 | 06:01 PM
transamsam98's Avatar
what exactly did you remove and where did you get your lightwieght carpet from? pm me if its easier please. very interested since I am building up a 2000 trans am 6 speed and am shootingfor sub 3000 lbs without my fat as in it.
Old Aug 9, 2008 | 09:15 PM
  #32
BAKED's Avatar
I got my carpet from Hobby Lobby, it's not easy to make it look good but if you take your time like I did then it can be done.
I posted earlier in this thread what weighed the most, there is also a weight reduction list in this section that tells what all everything weighs.
Old Aug 10, 2008 | 04:07 PM
  #33
LS WHAT's Avatar
mine weigh 3020 with out me in it. i had every thing inside but the back sets still had the stock power brakes and stock suspension. but i had a carbed 422 sbc in it i just had all the B.S. under the hood gone and front and rear bumber
