Drag Racing Tech
Patching Drag Radials
Old Aug 2, 2008 | 09:55 PM
98Camarod's Avatar
Default Patching Drag Radials
Has anyone had success with this or should I just buy a new drag radial? I purchased these drag radials from a local guy and when I had them mounted and balanced one of the radials has a hole in it. They plugged it without asking me. Is it possible to remove the plug and patch it from the inside and be care free to do some runs at the track?
Old Aug 3, 2008 | 03:54 AM
BayAreaSS's Avatar
The same thing happen to me. I bought my dr's used and one had a hole in it. So i plugged it. Its been good ever since and it has about 7 passes on it and 3k miles
Old Aug 3, 2008 | 11:08 AM
98Camarod's Avatar
You plugged it or patched it?
Old Aug 3, 2008 | 11:27 AM
Tally TransAm's Avatar
remove the plug and patch it as soon as possible before moisture can enter the plies
Old Aug 3, 2008 | 12:09 PM
Villain281H's Avatar
7 Second Club
From: Gainesville, Florida # of drag strips runs: ?!?!?
I'd patch it from the inside. I've done this on a few sets of slicks as well as seen it done on drag radials. Works better IMHO than a plug than could come loose.
Derek
Old Aug 3, 2008 | 08:18 PM
QuietSS's Avatar
I think u are best off patching it from the inside asap as these guys have stated.
I dont think u would run into a tire problem as long as you aren't planning big MPH for the radials. Judgin by your sig u should be just fine. Good luck
