Going slower after TH400 install
Before the swap the car went consistent 11.40's @ 116-118with a 1.59 60'. Now leaving off the brake around 4K RPM I am only getting 1.7x 60' and running 11.80's @ 114-116. The TH400 has a standard 2.48 first gear. I am running a 3.70 gear in the 9" and a 28" tire.
Does this seem common? Should I re-tune the car with the new trans/converter setup? Any recommendations?
Thanks,
Leo
I had the same power numbers with the 4L60 and never trapped in the 120's on motor.
Weight with me in it is 3800 lbs.
Not sure of what the DA was, but it was at Norwalk this past weekend, racing at 2 am and 5 am so it was cool out...great air.
I was figuring more gear.
The MPH has always been low for the car. It is heavy @ 3800 lbs. PSJ's Camaro was very similiar to my setup (Same engine/head/cam/intake) and he was running 11.00's @ 120+. Though his raceweight was alot less than mine. Now he did have 4.10's and I have 3.70's
Old converter was right around the same stall speed.
I have not tried leaving softer at all. Well, I guess i did. I went from matting it on the brake and leaving at 4600 to just getting to 3K and really didnt have alot of change.
While not optimal it shouldnt have killed the car that much if thats the same gear/tire you ran before. The 3.30 or whatever 1st gear probably helped out some in the 60' department though..Also use a 2 step with the brake around 3000rpm, dont just leave WOT with the brake. If the converter is close using the brake or footbraking wont make a huge difference in ET.
Not to mention the weather, check the DA. MPH shouldnt have been affected much if the converter is halfway decent.
With the 4L60 I went 10.54 @ 124 with a 100 shot. With these times I am thinking Ill need the 200 just to get back to that kind of ET
We have the Pontiac Nationals this weekend and I am going to try the spray and see what happens. I am having a feeling that the car isnt going to do what I was hoping for though.
The car feels like it pulls harder than it did with the A4, but obviouslly the ET says different. Maybe that is just because the shifts are more positive now?
This MUST be done or your car will go into a "limp" mode. It doesnt see the trans shift out of park so it throws everything off.
Ask me how i know lol. I just swapped in a th400 last year and with stock tune car went 12.6's and once i swapped to a m6 tune to delete the trans codes i ran an 11.9's. Nothing changing except for removing the 4l60e trans stuff
It was a complete turd before tuning out the trans stuff.
Do that ASAP and you will notice a HUGE difference.
Sorry i didnt see this earlier.
I went from 11.4s N/A to 10.9s N/A swapping from a 4L60E to a TH400 keeping the 3.73 gears. I am trapping 121MPH so far and running a very tight 8in conveter coming out at 4k
I have one for sale that would probably work like a charm for your setup, I went 10.50's with it n/a off the footbrake with th400, flashes to about 5400 but for what you're doing it should be right on.
Works good with 100 shot too, any more then that and it's too loose.
You have gearing/tire/converter size for 300 hp more then you're making, that's what's slowing it down.
