How much gear????
1999 Z28 3200lbs with me in it
347 H/C/I/ stages of N20, 150 off the line, 250 60' out.
Powerglide W/ very tight N20 converter probably around 32-3400
9" W/3:55's
325-50-15's
7200 RPM's max
I Ran 9.7's with my old setup, spraying a 200 shot and I had a th400 with a 3800 stall. It was blowing through the converter really bad so I sent it back. I also put a powerglide in it after the re stall. Now the car needs more gear in a bad way. My question is: How much bigger can I go? I have had people tell me that I'll be ok with 4:30's and I've had others say that 4:10's would be too much. The car should be good for some LOW 9's at around 145 or so.
I could care less how the car performs on motor, it is a nitrous car so keep that in mind. The car made 711rwhp on one stage on juice, it should be somewhere around 800-825 with both stages going.
Any help will be appreciated.
-BAKED-
I have twisted the motor to 7600 so if it's close at the finish line I'll be ok.
What do you think the optimal gear would be for my car?
I will let the N2O guys jump in and comment on what the best option or compromise may be.
A good friend of mine has a 4:11 I'm gonna try, if it's too much I'll go with a 3:90 or 3:73
